HELP, stranded in Cheeseland.
Old Jun 11, 2007 | 02:55 PM
dmueller71's Avatar
dmueller71
Unhappy HELP, stranded in Cheeseland.
OK, It could be worse. I'm in Wisconsin, fishing till Friday. But, my truck won't start. I've been having an occasional problem in the mornings, where it would start, chug a little bit and die. It usually starts up after that and is fine. Once, after I replaced the GPR a few weeks ago, I jumped the GPR and it started, but that hasn't worked today. I actually don't think it's a GPR problem. Any other ideas from anyone?? Even though I'm playing for a few more days, I eventually need to go home. Thanks guys
Old Jun 11, 2007 | 03:08 PM
F250_'s Avatar
F250_
CPS, perhaps?
Old Jun 11, 2007 | 03:24 PM
fbilly420's Avatar
fbilly420
i was also thinking CPS. Got a spare?
Old Jun 11, 2007 | 03:32 PM
ponch37300's Avatar
ponch37300
Where in wisconsin are you? I just had to replace my cps so i don't have a spare to try but could take my new one out to see if that's it. Let me know if you need any tools or help. I live in Appleton, about 20 minutes south of Green Bay.
Old Jun 11, 2007 | 03:42 PM
dmueller71's Avatar
dmueller71
I'm in Edgerton, just North of Janesville. I guess I've had too many beers today. I'll try the cps now.
Old Jun 11, 2007 | 04:08 PM
dmueller71's Avatar
dmueller71
OK, tried the CPS. No go. There is always the possibility that my backup is bad, because it is the original one to the truck. I replaced it about three years ago, because I thought that was the problem, but it wasn't. Any other Ideas?
Old Jun 11, 2007 | 05:17 PM
MAKO314's Avatar
MAKO314
have you checked all the fuses? can you hear the fuel pump running with the key turned on, it's under the driver's side frame rail. what about the oil level in the HPOP resivore
Old Jun 11, 2007 | 05:26 PM
ponch37300's Avatar
ponch37300
What about a loose uvc harness?
Old Jun 11, 2007 | 07:34 PM
dmueller71's Avatar
dmueller71
yes to the fuel pump. UVC I have to check. It's just wierd how it started twice actually, and then just won't fire again
Old Jun 11, 2007 | 08:59 PM
maevans's Avatar
maevans
I know it sounds to simple, but check your oil level, Also check your batteries with a meter, one more-check your fuel filter. Good luck.
Old Jun 11, 2007 | 10:15 PM
dmueller71's Avatar
dmueller71
Fuel filter was changed 2 weeks ago, batteries are fine, it cranks like they're new. Changed oil last thursday. I found an International dealer in Janesville, so I'll probably try another CPS. Or should I I try one of the new ones from Ford? I've heard a lot from you guys about them, but no reports on the quality. Does International have the same $25.00 cps?
Old Jun 11, 2007 | 10:19 PM
dmueller71's Avatar
dmueller71
A quick question about the HPOP. Doesn't that get oil from the motor? So then if it does, and I drove the 2.5 hours up here, and the motor is clean, ie. no leaks, how can it be low? Not being a smart butt, I have just never had to touch the HPOP yet, so trying to understand.
Old Jun 12, 2007 | 07:01 AM
ponch37300's Avatar
ponch37300
Someone might be able to give more info but i believe the hpop has a check valve in it that can go bad and the oil will drain back into the engine. There is an allen set screw(once again i believe, haven't ever checked mine but remembering from reading on this site) on the hpop that you can take out and check the level of oil in there to make sure the hpop has the oil it's supposed to. Hopefully someone else will chime in and give more info or correct me if i'm wrong.
Old Jun 12, 2007 | 07:59 AM
Action4478's Avatar
Action4478
Just a WAG...have you checked the fuses?...#30 in particular.. Poweres the fuel heater & the PCM....
Old Jun 12, 2007 | 08:20 AM
dmueller71's Avatar
dmueller71
yes, fuses are all good. I'll look into the hpop after I run to town for some allen wrenches
