ingnition switch problem
Old Sep 19, 2012 | 03:31 PM
brokersteve's Avatar
brokersteve
I took my dash apart recently in order to install my aftermarket a/c kit and to paint the dash. While back there pulling everything out, I pulled the ignition assembly off. I was not aware of the trick to use a paper clip and the key to remove it properly. At any rate, the piece came off pretty easily, however, three copper springs and retainers popped out as well. Not aware of what I did or how to put everything back together. I'm pretty sure the springs go in the black plastic piece with the retainers on top, but have no idea if that's all I need to do and how it snaps back together. Any tips, instructions, thoughts (besides the fact that I'm an idiot, LOL)? I could not find anything through searching, or in my Hayne's manual. Thanks.
Old Sep 19, 2012 | 03:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You might have to replace the ignition switch. Normally when you remove the lock cylinder from the ignition switch there are only two parts, the lock cylinder and the switch body. I don't think there are supposed to be any spare parts.
Old Sep 19, 2012 | 04:12 PM
fmc400's Avatar
fmc400
MSEE
Just replace the switch. The switch carries heavy current, and room for error is low. It's cheap enough just to eliminate all risk and get a new one.
Old Sep 19, 2012 | 05:26 PM
brokersteve
If I have to replace the ignition it's no big deal. I would like to retain the same key for the door locks. Can I take the new ignition to a locksmith with my current key to have it keyed appropriately? Thanks.
Old Sep 19, 2012 | 05:40 PM
jim collins's Avatar
jim collins
You probably can,but you can buy new locks and ignition cylinder for about the same cost. I just did that with mine as my locks were getting worn and i only wanted one key. It may be different in your area though . The switch was being sold with out the key cylinder , so i went that way.
Old Sep 19, 2012 | 05:58 PM
brokersteve
So I really just need to buy the new ignition and can keep my key cylinder, right? Good. I'll just do that. Thanks.
Old Sep 19, 2012 | 06:23 PM
jim collins
The cylinders are a little tricky to instal if it's your first time. You will need to use the paper clip to push the little button and turn it in position . Then line every thing up and it should go right in. Turn the key to on and pull out ,it should be locked in at that point. Good luck,
Old Sep 19, 2012 | 06:32 PM
MAULMAUL's Avatar
MAULMAUL
A little tricky is right. I think I would rather set the engine in again, rather than put that ignition switch in twice. I was particular about using the same switch/key since it was Pop's Truck, but if that were not the case, I would have just replaced everything at the drop of a hat.
Old Sep 19, 2012 | 07:54 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Here's a pic of the release pin hole.
mr.badwrench
Jun 4, 2018 11:10 AM
RedBoat
Jun 27, 2006 04:18 PM
Ed
Aerostar
15
Dec 3, 2005 08:38 PM
mositso
Oct 14, 2004 12:47 PM
jcs1966
Nov 27, 2002 01:33 PM
