Door/Ignition Question
Old Nov 26, 2002 | 08:30 AM
jcs1966's Avatar
jcs1966
If I buy the new/repro ignition switch & matching door locks will that that some of the slop out of the ignition switch? WHat does the repro BEZEL do? Does the SWITCH itself get play in it?
Old Nov 26, 2002 | 10:23 AM
William's Avatar
William
You have three areas to be concerned with. The switch, the lock cylinder and the bezel/mount. Usually the bezel and the mount hole in the dash are damaged by people removing the switch without experience and damaging it. Try this. Disconnect the battery. Put the key in the switch and turn it to accessory, stick a small piece of wire in the little hole next to the key and remove the lock cylinder. Then remove the switch and bezel. Determine what is worn or damaged and replace it. The hole in the dash can usually be repaired with a little hammer work. Let us know how this comes out.
William in Atlanta
Old Nov 27, 2002 | 08:10 AM
jcs1966's Avatar
jcs1966
How does the BEZEL piece come of without ruining anything?
Old Nov 27, 2002 | 01:33 PM
FTE Ken's Avatar
FTE Ken
uknunn
Apr 6, 2017 06:56 PM
gaffmedic
Apr 5, 2017 02:15 PM
1964FORDTUF
Jul 5, 2016 09:00 PM
John Morton
Jul 4, 2016 12:09 PM
Mercmeister
Apr 17, 2016 10:07 AM
