The screws that hold my window handles on, both have broken off inside the little post with teeth on the outside, i cant get them outt so i was thinkin i could take the posts out of a 78 f150 donor truck i have, but cant figure out how they come out, any ideas on how to get em outt?
The "posts" are an integral part of the regulator assy. and can't be separated. If you want to change the "post", you'll need to change the complete window regulator.
no i dont want to do that, i put the handles back on when i need to roll the window up or down, its just kind of ghetto, and id liek to figure out how to get it back on, without glueing or jb welding it onto the post, if i do that then i wont be able to take them back off if i need to get to my speakers or door panels
any hobby shop or hardware store has them idk maybe even wal-mart i build and tinker with them constantly they aren't cheap but they aren't super expensive either small ones i would use i found on amazon they are super cheap but then you would have to wait a little while
With a small burr in a Dremel tool, work a slot into th center of the broken off screw. Spray kroil around the screw and wait a few minutes. you should be able to remove the screw with a flat blade driver.
Thanks mann, ill try that, i have no clue what kroil is though, could i just use wd40 or something like that?
thanks! if phils idea doesnt work ill probably go with the magnetss
