Problem with my driver side window
Old Sep 18, 2006 | 10:27 AM
Bertha1's Avatar
Bertha1
Cool Problem with my driver side window
Hopefully someone can shed some light on this for me. My driver side power window was not working in my 87 f150 xlt lariat. I took off the door panel and noticed the regulator and motor seemed to be funtioning properly but the regulator was not in the track of the window. After some doing, I got the regulator on the window track and thought all was going to be fine. Now the window seems jammed because it won't move using the buttons and is extremely difficult by hand. Could it be the wrong window for the truck? I don't know what to do next other than take it to a shop. Please help!!
Old Sep 18, 2006 | 11:33 AM
samahi72's Avatar
samahi72
We are having a similar problem with our 87. You have to push the window up at the same time you are engaging the power window. I will be watching your post for the answer. It sounds like a common problem for vehicles this old.
Old Sep 18, 2006 | 11:59 AM
Conanski's Avatar
Conanski
So are you saying your window will stay up without the regulator attached? If so it's definitely jambed or incorrectly installed, it should free fall into the door. Check the track on both sides for damage or dislodged/damaged rubber track insert.
Old Sep 18, 2006 | 01:07 PM
Bertha1's Avatar
Bertha1
Yes, it was weird because the window was not being held up by anything other than the tracks on either side. When you move the door back and forth it sounds like there is broken glass in the bottom. I'm thinking the window was broken and replaced incorrectly. Is there a way to tell that the right size window is in there?
Old Sep 18, 2006 | 01:55 PM
Conanski's Avatar
Conanski
The windows are all the same. But the tracks are held on with bolts lower down on the door, and there is some play available to loosen or tighten the fit. Rust in the tracks could also be pinching the window enough to make it bind.
Old Sep 18, 2006 | 02:37 PM
Bertha1's Avatar
Bertha1
I did loosen 1 bolt that allowed me to get it back on the track but didn't notice any others that looked related. I am thinking about taking it to the shop for them to look into some other items and may mention the window to see what they say. I know it's not the motor or regulator so at least I go in somewhat educated.
Old Sep 18, 2006 | 10:25 PM
albung's Avatar
albung
i dont know bout window falling down.as it didnt fall on mine but had a bad gear on window motor it was 20.00 at autozone and you have to drill out rivits bet it is your prob
Old Sep 19, 2006 | 07:33 AM
Bertha1's Avatar
Bertha1
I can tell the regulator and motor has been changed before because the rivets are gone and it's held up with bolts and nuts. Plus, there were 2 regulators and motors in the tool box that I guess are the ones he replaced. The window is so hard to move, I doubt the motor has enough horsepower to raise and lower the thing!
Old Sep 19, 2006 | 08:50 AM
Conanski's Avatar
Conanski
It's jambed then. Taking the glass out is not at all hard..
Lower the main window all the way.
Remove the 2 screws/bolts on the leading sloped edge of the door which holds the 1/4 window frame. They're under the rubber door seal.
Remove the front track bolt just below the 1/4 window twist lock.
Pull back on the top of the 1/4 window assembly, twist and remove it from the door.
The main glass would be loose now and it should easily slide off the regulator.. so you can lift it from the door. Inspect the tracks and rubber linings for problems, bends, deterioration, rust... anything that will impede smooth operation. Both front and rear tracks should have a gentle curve.
Old Sep 19, 2006 | 10:17 AM
Bertha1's Avatar
Bertha1
Awesome!!! Thanks so much for the detailed instructions. I'll be buying a book (Chilton or Haynes, any suggestions on which is better?) this weekend so I can try to limit the dumb questions.
