Driver Window struggling
Old Jun 23, 2008 | 09:52 PM
ty20404's Avatar
ty20404
So many of you will read my other post regarding some old and tired door locks but the driver's window is heading south also. I'm guessing that it can be one of two things: The felt window seals are pressing too hard against the window putting too much strain on the motor/regulator, or the regulator/motor is going bad. My dad has told me that when the window is wet it has no problem going up or down which leads me to believe the gap for the window has become narrowed (from being hit or the like), causing too much strain on the regulator/motor. Any help into this is very appreciated. Thanks!
Old Jun 23, 2008 | 10:20 PM
wallz's Avatar
wallz
Roll the window down and spray the side channels with a silicone spray. Also a good idea is to remove the door panel and lube up the regulator with some grease, and when in there, raise up the glass and spray the bottom parts of the glass channels with the said sili spray. Move window up and down several times and you should be set.
Old Jun 24, 2008 | 03:28 AM
AK-Excursion's Avatar
AK-Excursion
My window scrapes on something and is making a vertical line on the outside of the window. Not sure if any of you have that problem but its kind of strange.
Old Jun 24, 2008 | 05:26 AM
1buzzbait's Avatar
1buzzbait
find AQUA-LUBE--that is the best chit ever--use sparingly!!!!
oh-yeah Kent Automotive makes it
vans
2009 - 2014 F150
Mar 20, 2015 09:23 AM
Fastolds
Ford Truck Parts for Sale
Apr 19, 2013 10:44 AM
expydaddy
Apr 20, 2012 05:32 PM
James Francis
13
Oct 10, 2011 07:01 AM
