on my 77 f150 the drivers side window likes to roll itself down 1-2" randomly and you can't actually crank the window up all the way close but not quite have to push/pull the window up the rest of the way. How do i go about fixing this? New window regulator? Window off the track and i just not know it? Never had to deal with this problem before.
Reason: left something out
The gears in the regulator ( crank ) are stripped and the slack plus the weight of the window causes the regulator to " sag ". Last time I checked, Dennis Carpenter had replacements for 100 dollars each. I got lucky recently and bought a pair of doors for 75. Each door had a recent replacement. Good luck, you may find some
