ONBOARD AIR COMPRESSOR
Onboard Air & Train Horn Ford Super Duty F350 - YouTube
And how long it takes this brand to refill his tires.
On-Board Air Compressor Tire Inflation Time - YouTube
In reference to the pump that clay sells...so does this put out enough air to run an impact run by itself with no tank continuously? I am not all that familiar with cfm's
thanks
I'm thinking of adding some sort of on board air on my truck, but nothing to run Impact guns, just for airing up truck & trailer while on the road. Keep the info coming...
Where did you get the compressor and what size. Where did you get the pressure switch and is it adjustable or has set pressure. Would you please show a wire and piping diagram.
thanks
Most cheaper standalone compressors aren't 100% duty cycle and/or don't generate enough flow at enough pressure to run air tools without a complementary air tank for reserve capacity.
The No Load specs are pretty meaningless, you need to look at the specs under load e.g. % duty cycle, CFM, psi & current draw under load.
You can now buy some really nice fully contained portable systems:
Extreme Outback:
Product : Extreme Outback
http://www.extremeoutback.com/ExtremeProducts.pdf
ARB:
ARB Twin High Performance 12 Volt Portable Air Compressor (CKMTP12)
http://store.arbusa.com/Assets/PDF/c...ifications.pdf
The advantages of a full contained separate portable system are:
- no install kit/time/cost
- can lend to a friend or swap between 2 trucks or vehicles, or even use standalone, you just need a battery with enough juice for as long as you need it
- you can leave it behind if you don't need it
- if you sell the truck, you don't have to let it go, or remove it
- convenient if you already have heavy gauge wiring run to the front and/or rear e.g. for winch or charging of travel trailer house batteries, as they normally use the same high amperage connectors, so you can just unplug & plug in portable compressor
The disadvantage is that they are expensive.
At the moment I've been getting by with a 10 lbs nitrogen tank, but I have been tempted by the 2 standalone systems above, or alternatively a York-style engine-driven compressor with a modest sized tank, possibly with an airtight front or rear bumper operating as the air tank.
Of course, you can also buy or cobble together a much more modest compressor & air tank.
It really depends on:
- how often you need an air supply?
- what performance (CFM, PSI, duty cycle) you need or are willing to tolerate?
- how urgent it is when you need it?
- how much you are willing to spend?
Viair Corporation - - VIAIR Ultra Light-Duty Onboard Air Systems - Overview - SummitRacing.com
Accessories ----> http://www.summitracing.com/search/B...r-Corporation/
