portable air compressor
Old Jul 7, 2007 | 06:34 PM
bing-bing's Avatar
bing-bing
I need a good portable air compressor to keep my tires aired up on the road. What brand would you all recommed and where would I buy one Thanks Bing
Old Jul 7, 2007 | 11:27 PM
RACERX7775's Avatar
RACERX7775
go buy one at pep boys that has a power inverter and a jump pack and compressor all in one. i have one like that.
Old Jul 9, 2007 | 04:11 PM
jackrista's Avatar
jackrista
made by interdynamics model hd300 air compressor plugs into cigerette lighter and can run for 8hrs stright, it has its own cooling fan. or any of viair compressors that are out there they are 300+ range where the hd300 is under a hundred $ i use a $10.0 special i got from kragens 4 years ago and still works good i keep it in the rockkrawler
Old Jul 9, 2007 | 05:41 PM
bing-bing's Avatar
bing-bing
Thanks guys I'll check those out.....bing
Old Jul 10, 2007 | 09:56 AM
andermac's Avatar
andermac
I've got a rechargeable Campbell-Hausfield($39) that I bought at Walley World. It will pump up 4 flats usually before recharge is needed and you can recharge it with one of those $12.95 100w dc/ac inverters from a truckstop. I keep one in my door for my laptop. I like it because of the no cord portability feature@ pumping up atv tires and trailer tires. It's a cheaper smaller setup than the booster pack and a little lighter in weight. However booster packs offer more power for jump starts and usually pump to higher pressures. Andy
Old Jul 10, 2007 | 11:42 AM
MarkMoore's Avatar
MarkMoore
I bought one a Sam's Club. It runs off it's own battery or 12v cigar plug. To recharge it, you can use the cigar plug, or connect any extension cord to it and it will charge (no need for an additional "special" plug). One of the selleing factirs for me on this one, was it has a Hi Pressure line for tires and a Hi Volume line for inflating floats or useing it as a blower. Works for me... no more huffing and puffing to blow up the kiddie floats!
Old Jul 10, 2007 | 02:28 PM
andermac's Avatar
andermac
Red face
your right, I forgot it came with that cigerette plug in, also a lighter to lighter plug for charging the battery thru the lighter if i remember right, now what did i do with them? Andy
Old Jul 10, 2007 | 06:25 PM
bing-bing's Avatar
bing-bing
I stopped in at home depot and got a Husky portable ac/dc power system. It will jump start my battery, pump up tires without being plugged in and it has an A/C outlet and cigar plug-in too. This allows my wife to plug in her curling iron and watch me as I work on the tires ect..All for 90 bucks...Gives 400 watts a/c power and 450 amps instant power and can pump @ 200 psi. It can also be recharged by a/c or d/c, comes with cables and adapters. Now I wanna go jump something or blow it up!....Thanks all for your input.....
Old Jul 10, 2007 | 07:15 PM
jackrista's Avatar
jackrista
be careful on what or who you jump and blow! lol
Technologiq
Apr 25, 2013 08:12 PM
grantschim
Jun 14, 2011 03:41 PM
daveengelson
Garage & Workshop
Dec 17, 2009 08:27 PM
rkstone
1997 - 2003 F150
Feb 24, 2003 09:21 AM
vinny8
Dec 5, 2002 12:53 AM
