I want to put an permanant onboard air compressor and tank so I can air up my tires on my 5th wheel, atv, etc. Want a good heavy duty compressor: I have tried the little self-contained units or ones that plug into the lighter. these are junk and crapped out after filling a couple of tires. Let me know what you are running. and post some pictures if you have them.
Thanks
Imagine an ExtremeAire Compressor with TWICE the power and speed, all in a package only 2" longer than the original! Now you can have a continuous 12 volt compressor that will put out 6 CFM free flow and a whopping 2.6 CFM at 100 psi. Nothing in its size, class or price range even comes close! The ExtremeAire Magnum utilizes a 1.5 HP fan cooled motor and longer piston stroke to make the impossible possible. The Magnum has all the key features of the original ExtremeAire such as superior filtering, stainless steel hardware, heat dissipation cylinder coating and powder coated filter housing and fan shroud. Plus it can be mounted in any angle or position, even upside down! Sealed bearings mean no servicing or lubrication is necessary. Since the unit is totally sealed from the elements, you can mount it under your truck on the frame rail so valuable storage space is preserved.
