Help, striped oil pressure sensor....
Aug 21, 2012 | 06:53 PM
Gauge for oil pressure on dash did not work when we got this 2005 F250 130K truck. Bought a sender for the gauge and pulled the bad one out as I unscrewed it it rocked as if it was not in all the way. It just came out threads and all. Not good. Now what? Sender has and o-ring on it so I guess its not NPT? Can it be drilled and hilli-coiled? Does this assemble come out easy? Whats the assemble called? Anyone have a Ford part number?
Thanks!
Aug 21, 2012 | 09:20 PM
Day keeps getting better. Was pulling off the intake pipe to gain access to the oil pressure sender mount thing and found this!
Guess turbo coming out now. WTF? This day started out easy, now...
So how bad is it to remove the turbo? Can you buy just the wheel?
Aug 21, 2012 | 09:27 PM
I would replace that turbo. Too much damage for me to trust it (ie imbalance is hard on bearings, looks like it is leaking oil, etc).
Aug 21, 2012 | 09:28 PM
Quote:
Originally Posted by
bismic
Really? Still ran great and made power. Sucks.
Aug 21, 2012 | 09:54 PM
Boy you are having a HELL of a Day Sorrey man
Mark is right that bearing is probably toast Anyway thats probably why the Turbine hit the housing
you do have alot of oil there alot more than normal anyway
But I think you can get All those parts I know you can get a bearing But Turbine IDK for shure
as far as the helicoil not shure either but you may need a Oil Filter adapter Plate
I MIGHT have a part# for that one hang on
But if you have to change the whole oil filter adapter just as well do the oil cooler too as the intake manafold will have to come out
Aug 21, 2012 | 10:01 PM
You ---- With your head under the hood ----- Drop the Wrench and move away from the vehicle! !!!! LOL
Aug 21, 2012 | 10:38 PM
I might be wrong the Oil seal is replacable but the bearing IDK
And your bearing is Likly BAD
5C3Z 6K632 A / 1844127C91-------------------------------------Turbo Assembly
3C3Z9T514AG / 1840053C96 -----------------------------------Turbo Hardware "Mounting" Kit
4C4Z 9V424 AA / 1870713C91------------------------------------Turbo Reconditioning Kit with Hardware
6C3Z 9T515 A / 1876071C91--------------------------------------Updated Turbo Drain
3C3Z 9T516 A / 1845287C96--------------------------------------Updated Turbo Feed
3C3Z 9t514 A / --------------------------------------------------Old Braided Turbo Feed
3C3Z 6C885 A /--------------------------------------------------Turbo Unison Ring
Second number is international dealer part# and usually cheaper
Aug 21, 2012 | 10:40 PM
the best thing is get a new OEM Turbo
and even better would be a Powqer Max turbo
Aug 21, 2012 | 11:14 PM
Fal-308-Win
Thanks, you made my day! That was well done. No offence to the OP.
Aug 21, 2012 | 11:26 PM
icantdo55 If you get rid of your damaged oil filter adapter I would be willing to buy it from you as I'm doing some R&D for a oil cooler pre-filter and I need a junked oil cooler with housing and oil filter housing adapter.
Aug 22, 2012 | 12:02 AM
Aug 22, 2012 | 12:58 AM
icantdo55
the problem isn't the wheel.
where are all the pieces that broke off?
the turbo is trashed.
Aug 22, 2012 | 02:59 PM
Fulthrotl
I agree.
I bet if you looked in the hot side of the intercooler
you will find the parts down in the bottom.
Sean
Aug 22, 2012 | 07:57 PM
If you plan on keeping your truck, i would recommend the power max turbo. They cost about the same as oem
Joey Fletcher
13
Oct 26, 2016 07:54 PM
BigBad___Truck
Mar 23, 2015 10:55 PM
John D in CT
Mar 15, 2012 09:14 PM
rmalottwtes30
13
Aug 26, 2011 04:48 PM
wreckinball
Jan 22, 2011 11:29 AM
