'93 Turbo - where to attach oil pressure test gauge?
on
Factory turbos and the 093 ATS system use the stock oil pressure sending unit location for the turbo oil supply and relocate the sender.
In that picture the CDR is labled.
Just below that is the glow plug relay with the two large yellow wires going to it.
If you follow the yellow wires toward the glow plug relay, just where they turn black, the oil pressure sending unit is just right and down a little.
You can see the single wire angle connector on the top center of it.
IDIDieselJohn was so nice to post this picture of the E series engine where you can see the back of the engine while it is installed, I borrowed it.
What thread is the oil sending unit?
Stock unit is 1/4" pipe thread if I remember right.
On the drivers side of the engine there is a row of five pipe plugs with 1/4" square heads.
Those are 1/8" pipe thread plugs that go into the oil gallery that distrubutes oil to the crank, oil jets and cam.
Any of those that are far enough from the exhaust and steering column would be OK to use.
That would also leave your stock gauge working as well.
If the 93 turbo is a stock Ford turbo unit, the turbo oil supply is where the oil pressure sensor is on a NA motor.
I ran a tee in the turbo oil supply line for a long time.
And I always had what I considered very low oil pressure at idle with a real mechanical gauge.
I moved my mechanical gauge feed from the turbo supply line down to the row of plugged ports and now have a true oil pressure reading.
And I feel a lot better about my hot idle oil pressure.
Use the square headed 1/8" pipe plugs on the drivers side.
In that picture just below the center main bearing cap, just below the oil pan lip you can see one of the plugs I am talking about.
It is to the left side of the main bearing slightly because of the angle the picture was taken at.
Look for a shiney square that the light is reflecting off of.
There is a plug just above the oil pan lip outboard from every main bearing cap, five in all.
Drivers side of the block is down in the picture.
The one for the rear main cap is way back and way out there, to close to the exhaust cross over.
If I remember right, number 4 main bearing plug is to close to the rear oil cooler header to get a socket on.
# 3 plug is right behind the motor mount, which I think is the plug I used.
#2 is behind the motor mount
And #1 is to close to the steering gear box.
If you look at the ones Dave is talking about, I want to say the last one at the end, for the rear main cap, is where the current ATS 093 kit taps into the block (instead of using the stock sensor port). It may be close to the exhaust, I don't remember, unless there is another plug in the same general area, but higher up. The kit comes with a right-angle fitting, so its aimed up along the block.
Yes, some of the aftermarket ATS turbos used those ports for the oil feed line instead of teeing off the stock sender location.
I want to say its the last one which Dave says is too close to the exhaust, but I can't remember off the top of my head. But any of them will work.
I don't remember any issues getting the plug out when I put my turbo on. I probably had the exhaust crossover off at the time, might have made access easier?
F250 89
11-02-2016 05:42 AM
CB3
11-19-2015 09:03 AM
ROBZ95XJ
12-28-2013 08:36 AM
