New Turbo......with questions
Well guys my luck continues to keep going south!
After months of messing with the brakes on this demon my wife takes the truck and horse trailer to Fancy Gap Va. for a week long horse ride up there with her friends.....
On the way up the truck blows up( I was not told of any of this until she got home a week later) she did call me and said the trip up there went well and no issues with the truck...........Oh well so much for the truth.
8 miles into Va. smoke and oil everywhere the truck was hauled to a repair shop close to there. I found out that the turbo housing had cracked and was causing all the problems with the running of my truck.
A rebuilt turbo was installed, 4 gallons of oil and new O-rings.
I went up there yesterday and paid the bill and got my fancy turbo wheel out of the old turbo and had an old one put back in for the core charge.
$2000.00 and on the way home I noticed that the oil pressure was going up.....It is normally in the R range on the gauge. before I got home it was one needle with past the L headed to HI.
What Gives?????
to increase pressure you must have a restriction........YES or NO ???
Should I be worried about this???
What Gives?????
Joey, I didn't install the gauge, the previous owner did. From what I can see though, it's connected electrically to a sensor installed in the port on the oil cooler. There are two wires coming off of the sensor leading to the gauge. The sensor looks like a Napa generic. They are pretty cheap.
My old man told me about it 30 years ago when installing one for a friend
I know where you shouldn't put it
Coil, what? Like they do in the brake lines? Interesting! I use the copper oil line. I tapped into the front part of the block, its a little square plug that's in the pressure part of the engine. I was already using the one above the oil filter for my FS2500 oil bypass system. I can take a picture if you want Joey.
Jmudweiser
07-29-2016 06:50 PM
d-day
26
04-17-2014 07:37 PM
