The wife was hauling hay the other day and '97 F-250 HD started smoking from underneath. Turns out it was transmission fluid flowing out from the torque converter area on to the exhaust. What will cause this? The trans is a Ford factory rebuild with 34k on it. Thanks for any help, PK.
Do you have a tranny temp gauge?, maybe it overheated.
We trailered it to the Ford dealer yesterday. It's 65 miles and they are a good outfit. I'll let you all know the out come. Thanks for the tips and help. PK
The dealership called today and said nothing was wrong with the transmission. They filled it up with ATF did some checks and it ran perfect. Going to get it in the morning and put it back to work. Thanks again, PK.
Glad to hear, but Id change ALL the ATF and the filter, because with the heat the ATF degrades (spl?) and lose some of its properties.
Also get a Tranny temp gauge.
