e4od
Old Jan 31, 2001 | 09:30 PM
capt scott's Avatar
capt scott
e4od
I have an 89 7.3 diesel dually with an aftermarket turbo and the infamous e4od. original trans crashed about 40k and was replaced under warranty in 92. now, another 40k later, more trouble. after towing my boat, it let out over 1 qt of fluid from inside the torque converter area. is the overflow in there? after cooling down some and again filling, I have driven it but not towed anything to get it real hot yet and have not had any more leaks. what are some ideas on this? I am a little nervous to start on a couple hundred mile trip with the boat wondering if it is going to gush fluid when it heats up!
Old Feb 26, 2001 | 06:09 PM
91f1502wd's Avatar
91f1502wd
e4od
Old Mar 2, 2001 | 05:28 PM
lawrence's Avatar
lawrence
e4od
I have the same setup in a 1990 F-250 4wd. The trans has been the weak link for sure. Here's what I've found with mine. These things get way hot! I've got 2 external coolers and it still gets over 200 deg on a really hot day. Make sure you run a temp gauge. I've switched to synthetic trans fluid. Do not tow in overdrive! Unless you've got a light load and no hills there's to much strain on it.When it finally takes a dump have it rebuilt by someone who really knows ford trannys and will put in good aftermarket clutches and torque converter. Good luck.
