Tranny Shutters
Old May 15, 2003 | 02:13 AM
Thom_James4991's Avatar
Thom_James4991
Tranny Shutters
Hey can anyone help me? I have a 1995 f-150 with a 302, the transmition shutters when it shifts to over drive. It also shifts hard into second gear. It is a 4R70W tranny....
Thanks.
Old May 15, 2003 | 12:56 PM
jim henderson's Avatar
jim henderson
Tranny Shutters
Hmm sounds like classic E4OD torque converter shudder. But you had a 4R70 which I know little about. I think the E4OD was an electronic version of the 4R70. Don't know if the 4R709 has the same weaknesses of the early E4ODs. I am a bit surprised the 4R70 was used in your model year since I think the E4OD started taking over in 90 or there abouts. Like I said I know little about the 4R70.
If your fluid is brown or light pink instead of red, or if it smeels burnt, then you may have toasted the seals and or added particles to the fluid which would cause intermittent harsh shifting and the shudder.
Some people are able to "cure" the problem with a fluid change or flush. If the seals have been damaged, you will probably need at least a minor rebuild. I would assume that there are new specification or up rated components for the 4R70, there are for the E4OD.
Good Luck,
Jim Henderson
Old May 15, 2003 | 03:27 PM
Thom_James4991
Tranny Shutters
Thanks Jim Ill give it a try...
Old May 15, 2003 | 07:52 PM
MikeMc100's Avatar
MikeMc100
Tranny Shutters
I had the same problem.....for about 3 yrs. When I did finally get the tranny power flushed with a filter change....it stopped. I fuuly expected to replace at least the converter. Hope you have the same luck as I did.
Old May 15, 2003 | 09:39 PM
vman's Avatar
vman
Tranny Shutters
My e4od shuddered real bad. Changed the fluid and it has been smooth ever since.
