New guy getting a 6.9.
Old Aug 1, 2012 | 02:20 PM
72f100390's Avatar
72f100390
hey yall im going to be getting a 84 f250 with a 6.9 soon i was told it has a knock (i havent heard it run yet) ive been reading alot these last couple days and noticed there are alot of reasons 6.9 will knock.
any advise on what to look for and what to listen for. hopfully i will get the truck to my house today and get it started so i can hear it and what its doing
Thanks
Cody
Old Aug 1, 2012 | 02:38 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Fire it up, and first see where the knock comes from (top end of bottom).
If top end, theres a pretty good chance it could just be a stuck open injector dumping fuel into a cylinder causing pre-ignition, and a knock.
Have it running, and while running, crack open 1 injector line at a time, if you crack one open, and the knock goes away, you found your bad injector.
Otherwise, could be worn valve guides. Other than that, isn't much to knock in these, i've rarely see an IDI knock from the bottom end as well.
Old Aug 1, 2012 | 03:17 PM
72f100390's Avatar
72f100390
alright thank you. that sounds pretty easy to do. is it bad to drive with a stuck injector?
Old Aug 1, 2012 | 03:24 PM
IDIDieselJohn
Avoid driving it, or running it for no reason while it's knocking, it could cause some more serious damage...
Old Aug 1, 2012 | 03:57 PM
72f100390's Avatar
72f100390
alright thats what i thought. thanks for the help i know gas motors but im new to diesels
Old Aug 2, 2012 | 01:41 AM
72f100390's Avatar
72f100390
well i got the truck today she runs great the knock is inside the tranny not the motor
Old Aug 2, 2012 | 01:54 AM
joshofalltrades's Avatar
joshofalltrades
if its an automatic, i've heard of the flex plate cracking and causing a knock. pull the tranny off and inspect the flex plate before you tear into the tranny itself
Old Aug 2, 2012 | 02:20 AM
72f100390's Avatar
72f100390
i has a 4speed
Old Aug 2, 2012 | 08:51 AM
ihateminimumwage's Avatar
ihateminimumwage
Is the noise constant, or does in go away when the clutch is engaged/disengaged? Any idea which part of the transmission it's coming from? Any drivability issues you've noticed? You can still pull the inspection plate and see how the flywheel and clutch look, if need be.
Old Aug 3, 2012 | 12:13 AM
72f100390's Avatar
72f100390
yes its consistant,no it does not go away with the clutch in or out,it sounds like the front like the flywheel. it drives and shifts good still but the knock gets louder when you get into higher rpms, i took the inspection plate off today and there are knicks on the teeth of the flywheel from where it looks like its hitting something small. heres a video of it.
MOV01956.mp4 video by 1967fordbronco - Photobucket
Old Aug 3, 2012 | 01:21 AM
lemonshindig's Avatar
lemonshindig
That sounds GNARLY! Pull that transmission out and see what the hell is going on.
76'SuperCab
Jun 29, 2013 07:47 PM
rayjann
Jan 26, 2012 05:42 AM
Rick Wallace
Aug 22, 2010 01:14 PM
powerstroked162
Jan 14, 2009 10:03 PM
