Sponsored by: Real Truck
X-gauge code
Old Jul 22, 2012 | 05:30 PM
DieselVol's Avatar
DieselVol
Originally Posted by DieselVol
I had my basics going (EOT,ECT, TFT). Then I added GER, TRQ, and tried ICP. I could not get ICP to work as it would never register at zero with the key on and engine off, even after I added the code adjustment for the 14.8 that I got with engine running. Now my EOT won't work. Any idea as to why?
Continue to ignore that question, 'cause after I turned the truck off an back on, the EOT started working again. Unfortunately, I have a new issue. The MAP (boost, really) read -0.4 with the engine off and the key on. I then just used the codes higher up in the list to finally get MAP to read 0.0 key on engine off. Now at idle, MAP reads 0.4-0.6. Should this also not be zero, or am I trying to get this thing to be too exact?
Old Jul 23, 2012 | 03:56 AM
Yahiko's Avatar
Yahiko
DieselVol
Do you have more than the SGII plugged
into the OBDII port? I found that made my
SGII unhappy and stalled the EOT. I had a Y cable
so I could have my Garmin ecoRoute™ HD
https://buy.garmin.com/shop/shop.do?pID=38354
The 2 don't play well together. The Garmin works and the
SGII stalls.
One of the guys over at the 6.0 forum posted a very
good listing of the X-guage codes. If you want it PM me
your Email address and I will send you a copy.
Sean
Old Jul 23, 2012 | 06:30 AM
DieselVol's Avatar
DieselVol
Originally Posted by Yahiko
DieselVol
SGII stalls.
Sean
It started working again and seems to be fine now. It sort of acted like a computer where you have to restart it after changes. I've added several more x-gauges since then and all seem to work. Any opinion on the boost question from above? Also, sending a PM.
Old Jul 23, 2012 | 07:24 AM
Chalkie's Avatar
Chalkie
Then I added GER, TRQ, and tried MAP.
I am curious as what kind of numbers GER is showing you. I set that up on my 6.4 and the numbers do not make sense to me.
Old Jul 23, 2012 | 07:47 AM
DieselVol's Avatar
DieselVol
1 is park, reverse, 1st gear and neutral. 2 and 3 are just that. There is no 4. 5 and 6 are 4th and 5th. No idea why this would be set up this way.
Old Jul 23, 2012 | 08:11 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I don't know why yours reads 1st in P and N, but there's it's not showing 4th because there's a 4th gear ratio that the trans doesn't use most of the time.
Old Jul 23, 2012 | 08:15 AM
texastech_diesel
Token Redneck
Old Jul 23, 2012 | 08:30 AM
DieselVol's Avatar
DieselVol
Mine is an '03, and thus uses the older PMW (I think that's right) system. Would that explain the difference? Do I need a different code to make it work?
Old Jul 23, 2012 | 08:37 AM
Chalkie's Avatar
Chalkie
That makes slightly more sense that what I am seeing (numbers like 17, 18, 19). I am going to check (again) that I set it up right.
jb95694
2015 - 2020 F150
24
Sep 26, 2020 01:49 PM
quadrider234
6.4L Power Stroke Diesel
Jan 6, 2019 10:11 PM
overthehillbill
29
Jan 3, 2012 12:33 AM
ambrose2004
Dec 26, 2011 09:42 AM
shadetreetx
Mar 16, 2009 11:08 AM
