6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
PO128 code override?
Old Jan 6, 2019 | 07:39 PM
quadrider234's Avatar
quadrider234
I recently just installed the Mishmoto aluminum radiator and low-temp thermostats in my 2008 F-250. Every so often my truck with get a check engine light with the code “PO128” which has something to do with the coolant temp being too low. My coolant temp runs around 170 degrees or so. Is there a way to over ride this code? Or would my only solution be to re-install my stock thermostats?
Old Jan 6, 2019 | 10:11 PM
speakerfritz's Avatar
speakerfritz
The code means the engine has not reached the expected warm up temp.
so if you have a thermostat that opens early....the pcm will cede this as a engine warm up problem.
youcantchange this on a 6.4 thru programming.
i would install the correct thermost
Super crew hunter
1997 - 2003 F150
Apr 11, 2013 06:41 AM
texastech_diesel
17
Feb 4, 2010 07:26 PM
Paul01
1997 - 2003 F150
Aug 16, 2006 01:46 PM
reiderb
Modular V8 (4.6L, 5.4L)
Apr 30, 2004 06:24 AM
spear52
Mar 14, 2003 10:46 PM
