scan gauge II help
Old Dec 25, 2011 | 03:30 PM
ambrose2004's Avatar
ambrose2004
scan gauge II help
so i just got a scan gauge II for x mas. as of right now im not seeing engine oil temp or coolant temp? can anyone give me advice on how to see it
Old Dec 25, 2011 | 03:57 PM
zhigaag's Avatar
zhigaag
I recommend searching for "x gauges" in this forum. There are many lists to choose from. Be prepared though. You'll spend a lot of time staring at the thing while you're in the truck.
Old Dec 25, 2011 | 06:07 PM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
Some x-gauges direct from their website.
Ford Specific XGauges
I think the coolant temp gauge is already on the SGII.
Old Dec 25, 2011 | 06:18 PM
nra4ever's Avatar
nra4ever
i have a scangauge that i got when they first came out. anyone know how to add coolant temp? its not on mine
Old Dec 25, 2011 | 06:45 PM
BLADE35's Avatar
BLADE35
coolant temp is already there at least on the newer ones
Its marked fWT = farenheight water tempiture NOT ECT like you think it would
theres also probably an x-gauge so you could name it what you want I dont think anyone uses it because it take one of the 25 positions
If you cant find Fwt post back Ill try and find the X-gauge for it
Old Dec 25, 2011 | 07:04 PM
nra4ever's Avatar
nra4ever
you are correct sir! found it.
Thanks
Old Dec 25, 2011 | 07:18 PM
BLADE35's Avatar
BLADE35
Thanks
Your welcome !!!
You can also verify the accuricy of the temp gauges and scangauge by comparing All Fluid temps [ECT,EOT,TFT] after a 12 hour cold soak they should read the same temp or atleast be within 1-2 degrees of each other.
some of the x-codes can be modified if you find a Bust thats out 1-2* at cold soak
Old Dec 26, 2011 | 09:42 AM
fixxxer-upper
FTE Fan
Try this one for ECT
ECT
07E0221139
046205110639
3008
000200010000
ETC Degrees F
I will take a look at mine when I get home and repost.
3000gtman
Dec 19, 2016 10:08 PM
Sooper Camper
Nov 30, 2013 09:24 PM
pmasley
Jul 20, 2012 08:49 PM
firedudecndn
Aug 17, 2005 05:06 PM
