shudder
Old Jul 13, 2012 | 10:16 AM
4getfulbj's Avatar
4getfulbj
found out it was my number 4 spark plug misfiring. finally running good. thanks for all the help and advice guys.
Old Jul 13, 2012 | 01:53 PM
Stewart_H's Avatar
Stewart_H
Thanks for posting a follow-up to let us know how you solved your problem!
Stewart
Old Jul 14, 2012 | 10:17 AM
4getfulbj's Avatar
4getfulbj
i found out that most people dont do that. but yeah its runnin great! thanks
Old Jul 15, 2012 | 10:40 AM
sambowheelgreaser's Avatar
sambowheelgreaser
I had a similar issues with mine as well and i had to learn the hard way. You must use OEM plugs in these trucks. they are peculiar as hell. While you are doing this, go ahead and check your primary and secondary OHM resistance for each coil. You can do this with most multimeters in your garage and it will take only 30 min or so. if a coil is .2 of an ohm off, that coil may be your culprit. Primary ohm- .55 secondary is 5.5kohms. (these numbers are for my 2005 5.4l) if your engine is the 4.6 or other, you can simply look up the resitance parameters for your model.
Old Jul 15, 2012 | 08:55 PM
patriotbump's Avatar
patriotbump
my shudder is at 1000 rpm's and idle ????
he cant figure out the shudder either. hahaha thats why im on here
other than 1000 to 1500 rpm's and at idle the truck (2004 ,5.4 , fx4) runs good but that is the main operating area ? don't know what is wrong, having the FORD dealership hook it up in the morning! any ideas?
Old Jul 16, 2012 | 04:42 AM
4getfulbj's Avatar
4getfulbj
when it shudders try to make the engine light come on. thats what i did. i kept the throttle in the shudder area. found out it was #4 and #8 spark plugs.
traildad
1997 - 2003 F150
15
May 15, 2013 10:13 PM
DJdemon6696
33
Sep 19, 2007 07:05 PM
hmebuildr
Aug 25, 2006 10:13 AM
SproutW
1978 - 1996 Big Bronco
Sep 29, 2005 10:03 AM
strikergc
Sep 28, 2004 08:21 AM
