E fuel question
Old Jun 24, 2012 | 09:42 PM
  #46
96ford250's Avatar
96ford250
are we talkin braided hose or aluminum line? because i thought aluminum line was only good to like 25 psi?
Old Jun 24, 2012 | 09:43 PM
  #47
mjonesjr's Avatar
mjonesjr
Aluminum fittings are fine.
Honestly, I'd get a straight 1/8"NPT x 6AN, the run a 45* 6AN swival. That is what I have and it allowed for me to put the hose fitting in any direction.
With the one you have linked you are at the mercy of the threads in the head.
Old Jun 24, 2012 | 09:47 PM
  #48
96ford250's Avatar
96ford250
alrighty that makes sense but about the line? i would like to run solid line because its cheaper then braided hose but what the psi limit on aluminum line?
Old Jun 24, 2012 | 09:53 PM
  #49
96ford250's Avatar
96ford250
so
this
Summit Racing SUM-220646 - Summit Racing® AN to NPT Adapter Fittings - Overview - SummitRacing.com
to this
Fragola Performance Systems 496206 - Fragola Performance Systems Couplers - Overview - SummitRacing.com
And on further research aluminum line is good to 25psi and the good stuff is 50psi and i'm not paying for braided hose id use flare fittings before i shelled out that kinda money. so what did you use for tubing?
Old Jun 24, 2012 | 10:11 PM
  #50
mjonesjr's Avatar
mjonesjr
I'd run a 6AN female x 6AN male and have a female fitting on the line.
I'm running rubber fuel injection hose that is rated for diesel with a push lock style fitting. The hose I'm running is rated at 250*, so I put a DEI sleeve on it that is rated for 2000* radiant and 500* direct.
Old Jun 24, 2012 | 10:17 PM
  #51
96ford250's Avatar
96ford250
yea i want to avoid rubber hose around the engine that's y i was going to go with flare fittings and run steel line. and the AN fitting are good but the aluminum tube doesn't hold the psi and the braided hose is more expensive then all the fittings are put together. I'm kinda lost on what to do
Old Jun 24, 2012 | 10:20 PM
  #52
mjonesjr's Avatar
mjonesjr
There is no down side to the rubber line and it is cheaper. Ford uses rubber line in the stock application.
Old Jun 24, 2012 | 10:22 PM
  #53
96ford250's Avatar
96ford250
Yea but it rots and leaks. y do flare fittings leak? ive never had problems with them.
Old Jun 24, 2012 | 10:24 PM
  #54
96ford250's Avatar
96ford250
so you went 1/8" to -6 AN to swivel to -6 AN to barb rubber fuel line bard to -6 AN to splitter?
Old Jun 25, 2012 | 10:15 AM
  #55
mjonesjr's Avatar
mjonesjr
I went 1/8" NPT x -4AN, then used a -4AN 45* swival x -4AN hose barb fitting. Then went with -4AN hose to a -4AN x -6AN reducer. The reducer was on a -6AN Y fitting that was connected to the original 3/8" tube with a 3/8" tube x -6AN fitting.
Here is the fittings I used on my supply.
Summit Racing SUM-2200075B - Summit Racing® AN to Tube Adapter Fittings - Overview - SummitRacing.com
Summit Racing SUM-220107B - Summit Racing® Y-Fittings - Overview - SummitRacing.com
Summit Racing SUM-220121-B - Summit Racing® Reducers - Overview - SummitRacing.com
Summit Racing SUM-220446B - Summit Racing® AN to NPT Adapter Fittings - Overview - SummitRacing.com
Summit Racing SUM-220705-B - Summit Racing® Twist-Tite Swivel Hose Ends - Overview - SummitRacing.com
Here is the fittings I used for my returns and regulator.
Summit Racing SUM-220166B - Summit Racing® AN O-Ring to AN Adapter Fittings - Overview - SummitRacing.com
Fragola Performance Systems 499206-BL - Fragola Performance Systems Radius AN to O-Ring Adapters - Overview - SummitRacing.com
Summit Racing SUM-220706-B - Summit Racing® Twist-Tite Swivel Hose Ends - Overview - SummitRacing.com
Summit Racing SUM-220632B - Summit Racing® Couplers - Overview - SummitRacing.com
Old Jun 25, 2012 | 02:23 PM
  #56
96ford250's Avatar
96ford250
i've decided to use flare fittings and i've found a 1/8" npt to 3/8" flare fitting and i'm going to run steel lines to a flared T fitting then run 3/8" flare to the side of the block then use a rubber jumper to go from the block to the frame then run 3/8" flare to the post filter then go from 3/8" flared to 1/2" npt
Old Jun 25, 2012 | 04:50 PM
  #57
Awitte58's Avatar
Awitte58
Late to the party, but great info on E-fuel!
Old Jun 25, 2012 | 08:15 PM
  #58
96ford250's Avatar
96ford250
thanks ill take pics on how it comes out its going to take a few days the parts are on order so i might be able to get started this weekend and ill make a parts list with prices for future reference
Old Aug 7, 2012 | 05:35 PM
  #59
mojoman's Avatar
mojoman
Thumbs up
I've been waiting to hear how this worked for you...and the aforementioned parts list...I'm ok for now but this fall I would like to get my truck fitted with e-fuel...thanks for an informative thread...
Mearntain
16
Jun 24, 2019 11:44 AM
AFoster1025
Oct 25, 2010 05:48 PM
renchr56
Sep 22, 2009 05:29 PM
RedSkin12B
Flathead V8 & Flathead 6
May 22, 2007 05:48 AM
mrweelr
1978 - 1996 Big Bronco
Jan 11, 2002 10:29 PM
