fuel system problems
Old Oct 24, 2010 | 11:30 AM
AFoster1025's Avatar
AFoster1025
my vehicle has sat for over a year. when i tried to start it the fuel pump was not kicking on, went through the motions of figuring out it was the fuel pump itself.
replaced the fuel pump, and filter.
no i can hear the fuel pump kick on, but still wont start. and there is no pressure at the valve on the fuel rail.
what to do?
fuel line blockage?
pump hooked up wrong?
anything else?
Old Oct 24, 2010 | 09:37 PM
alloro's Avatar
alloro
Did you change the fuel filter? It could be load up with gunk or something.
Old Oct 24, 2010 | 11:00 PM
AFoster1025
yes i changed the fuel filter
Old Oct 25, 2010 | 07:38 AM
alloro's Avatar
alloro
I'm sorry I wasn't clear, I meant did you change the filter again after changing the pump? Once working, the new pump could've moved sediment from the tank and into the fuel line, clogging the filter.
Old Oct 25, 2010 | 11:45 AM
AFoster1025
ok , now i see what your saying. No i didnt change it the second time. even if that were the case, wouldnt you think there would be a slight sputter from the engine?
Old Oct 25, 2010 | 05:45 PM
alloro's Avatar
alloro
Originally Posted by AFoster1025
even if that were the case, wouldn't you think there would be a slight sputter from the engine?
Not if fuel wasn't getting past the filter. It's just a thought since you're not getting fuel up to the fuel rail.
Old Oct 25, 2010 | 05:48 PM
madsonp's Avatar
madsonp
Your engine wouldn't sputter if it plugged off again right away. You could cut open the one you pull off to see what it looks like inside, and to help determine if for sure this is your problem. Of course, don't use a grinder or electric tools to do this because of the fuel or vapors that may still be in the filter, I suggest a hacksaw.
5oh95
Feb 3, 2025 07:10 PM
MYBOYDAVE
Sep 9, 2013 04:15 PM
deanna197
May 28, 2011 08:21 AM
BeauHymel
Modular V8 (4.6L, 5.4L)
Feb 23, 2010 01:42 PM
oldfrt84
Feb 21, 2008 04:31 PM
