E fuel question
Old Jun 24, 2012 | 11:59 AM
96ford250's Avatar
96ford250
the post filter is 1/2" coming out so it can come down to 3/8" hose and run the hose to the engine and go to 5/16" stainless up the the splitter?
something like this
Tubing, Seamless, 5/16 In, 6 ft, 304 SS - Stainless Steel Tubing - Pipe and Tubing - 3ACU2 : Grainger Industrial Supply
ill use hose for the filter and pump connections
Old Jun 24, 2012 | 12:12 PM
pjwoolw's Avatar
pjwoolw
I'd keep the whole system 3/8". Then everything is common to one size hose and fittings.
Old Jun 24, 2012 | 12:17 PM
Talyn's Avatar
Talyn
Agreed.
I'd rather have flow overkill anyways as long as the pump can push the volume.
Old Jun 24, 2012 | 12:26 PM
96ford250's Avatar
96ford250
that's why i want to go 3/8" hose off the post filter then when it gets to the engine go to 5/16" ss line up to the splitter then from the splitter to the head use the same 5/16" ss line. 3/8" is pretty common size for fuel line and 5/16" slips into 3/8" hose and i dont intend on blowing and ss lines any time soon. its still over kill but its easier then ordering another size of tubing
Old Jun 24, 2012 | 12:27 PM
mjonesjr's Avatar
mjonesjr
Originally Posted by Talyn
Agreed.
Unless you replace all the fuel lines from the selector valve all the way to the heads with 3/8" line, you can't keep the system 3/8". Even if you do replace it all with 3/8" line, your fuel pump is 5/16".
Here is my setup under my truck. My Stanadyne fuel/water separator is 3/8" inlet/outlet and my final filter is 1/2" inlet/outlet. I used 1/2" NPT x 3/8" Hose barb fittings on my final filter.
Old Jun 24, 2012 | 12:33 PM
96ford250's Avatar
96ford250
that's what i want to do then run the 3/8" hose off the post filter to the engine then at the engine step down to 5/16" like the pump all the way to the heads
Old Jun 24, 2012 | 01:11 PM
pjwoolw's Avatar
pjwoolw
I still don't see any reason to do so. Unless your not going to change the fittings at the heads.
Old Jun 24, 2012 | 01:22 PM
96ford250's Avatar
96ford250
so i don't have to buy different tubing and fittings its no different then doing it at the splitter so i might as well save my self the time and just use all the same size and its the same size coming off the pump. Ill take a pic or maybe even add to the write ups about it
Old Jun 24, 2012 | 04:00 PM
rodneywar's Avatar
rodneywar
Agreed.
agreed here as well i got it setup 3/8ths line all the way from tank to head and head back to tank happy with it and easier to find fittings for it as well
Old Jun 24, 2012 | 04:14 PM
96ford250's Avatar
96ford250
my fitting coming off my head is 5/16" is that right as in the flared steel line is 5/16"
Old Jun 24, 2012 | 04:50 PM
mjonesjr's Avatar
mjonesjr
No, Ford used 1/4" line from the banjo bolt to the head. International used 5/16" on the DT444.
Old Jun 24, 2012 | 08:44 PM
96ford250's Avatar
96ford250
ok thats fine but i took the fitting out of the block took it up to home depot and it screwed into the 5/16" fittings and not the 1/4" so im not sure how mines different but it is
Old Jun 24, 2012 | 08:53 PM
  #28
mjonesjr's Avatar
mjonesjr
Which fitting did you screw onto 5/16"? Post a picture of it.
I bet you are talking about the fitting that slips over the stock fuel line. That fitting probably is 5/16" because it is sealed by a rubber o-ring.
The fitting in the head is 1/8" NPT and the OEM fuel line is 1/4".
Old Jun 24, 2012 | 09:04 PM
  #29
rodneywar's Avatar
rodneywar
i think he is talking about the vibralock fittings in the back of the head the lines are 1/4 to a 5/16 vibralock then it goes 5/16 vibralock to 1/8th npt is a fitting in the back of the head
Old Jun 24, 2012 | 09:09 PM
  #30
96ford250's Avatar
96ford250
i was talking about the pipe fitting in the head
