E fuel question
Old Jun 24, 2012 | 09:12 PM
  #31
mjonesjr's Avatar
mjonesjr
I guarantee the end of that fitting that goes into the head is not 5/16". It is 1/8" NPT that goes into the head itself.
The end that connects to the stock fuel lines might be 5/16" because of the o-ring seal that is there, or the Vibralock fitting as it is called.
Old Jun 24, 2012 | 09:15 PM
  #32
rodneywar's Avatar
rodneywar
the vibralock fitting is 5/16ths to 1/8ths
Old Jun 24, 2012 | 09:17 PM
  #33
96ford250's Avatar
96ford250
yea thats the one has anyone found a good place to get a fitting that goes from 1/8" npt to 3/8" flare?
Old Jun 24, 2012 | 09:18 PM
  #34
mjonesjr's Avatar
mjonesjr
Correct, but the fuel lines are 1/4" and the port in the head is 1/8" NPT.
Old Jun 24, 2012 | 09:19 PM
  #35
rodneywar's Avatar
rodneywar
that is correct as well i just filled in the blank area between the fuel line and head for you if you get my drift
Old Jun 24, 2012 | 09:20 PM
  #36
mjonesjr's Avatar
mjonesjr
Why not get a fitting that is 1/8" NPT x 6AN if you want to use 3/8"? 6AN is 3/8". Then use AN fittings which seal better than flaring tubing.
Old Jun 24, 2012 | 09:25 PM
  #37
96ford250's Avatar
96ford250
AN gets expensive though doesnt it?
Im looking for this fitting but not in a 10 pack
https://www.grainger.com/Grainger/PA...-Degrees-5WRX3
Old Jun 24, 2012 | 09:26 PM
  #38
rodneywar's Avatar
rodneywar
thats what i did for both sides works really well and easier to adjust it for clearance from the turbo
Old Jun 24, 2012 | 09:27 PM
  #39
mjonesjr's Avatar
mjonesjr
You wont be able to use a 90* fitting. You won't be able to turn it out without hitting.
AN fittings are not that expensive. I'm running all Summit Racing branded AN fittings and they are at most $7 a fitting. Most of the fittings I used were around $3-$4 each.
You will need a 45* fitting on the driver side head.
Old Jun 24, 2012 | 09:28 PM
  #40
rodneywar's Avatar
rodneywar
any local hydraulic shop will have the an fittings you need and wasn't expensive for me it cost 35 dollars for 6 fittings total
Old Jun 24, 2012 | 09:32 PM
  #41
96ford250's Avatar
96ford250
I need steel AN fittings right? or is the aluminum ones just fine
Old Jun 24, 2012 | 09:36 PM
  #42
rodneywar's Avatar
rodneywar
i used the steel ones and yea i would think the aluminum ones would be fine as well
  #43
96ford250's Avatar
96ford250
So say 2 of these then just run AN line?
Fragola Performance Systems 482362 - Fragola Performance Systems AN to Pipe Thread Fittings - Overview - SummitRacing.com
Old Jun 24, 2012 | 09:40 PM
  #44
rodneywar's Avatar
rodneywar
yup 12345678
Old Jun 24, 2012 | 09:41 PM
  #45
rodneywar's Avatar
rodneywar
i added a 45 degree an to an fitting to help keep the lines closer to the heads
