Android Torque App
With this thread I was able to get my tranny fluid temp working and my eot working. I cannot get current gear to work however it always comes up 0, also what does the VGT mean its around 60-70s idling and high boost is low 30s.
I was also wondering what else i should be tracking on my 6.0, my truck is only stock for now with the exception of an egr delete but it is fun to play around with this app.
Thanks, Mike
Not sure why your gear isn't reading correctly, assuming you have an auto.
I also have the misfires on a couple screens, but haven't had a need for them.
Several issues I thought were from the BT OBDII unit I bought turned out to be solved with calc or header data that has been mentioned in this thread.
I set up a sloppy real-time screen and it's raised some Qs from me:
There are 3 PIDs that I think are related to the FICM: FLP, FVP and FMP. I watched carefully on start-up and only the FMP shows the voltage that we want out of the FICM -- mine ranged from a low of 47 to 48.5 and most of the time was 48V.
The other two: FLP and FVP read at a low of 13V to 14V and usually were around 13.5 -- is this right or do I need to change the calc so it's relative to the 48V range? I'm clueless....
It was nice to see my ECT and EOT never got farther apart than 10 deg.
So how do you change a realtime screen once you've placed a new gauge on it you don't want? Is there a way to move the gauges around or re-size them once you set-up a display? I've started from scratch several times now...
This is cool stuff, but dang my droid razr was HOT after a 45 minute run... Maybe I'll look for a dedicated droid device...
Thanks in advance for any advice you might have...
As for FICM readings. Your readings are correct!!
FICM Vehicle Power FVP (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
From what I read in the TSB, this low volts in FVP should throw a code P1378, with the new flash that came out in the TSB above.
FICM Logic Power FLP (Volts) (Should be 12 volts)
And I think, not for sure, both of these can give us a heads up that there is an issue developing in the battery system.
And, as for helping the developer, nah, I just posted questions to him. Ian has done the most. There is also a guy on some of the forums, Jester something. He put together a lot of the codes specific to our trucks.
I read a post, maybe it was yours (I've been reading sooo many on Torque or just data we can get off the CAN BUS) That I can get the strategy version for both the FICM and ECU? (sorry, whatever the heck the main control computer is called).
and..... once I find those I can figure out if I have the "FICM Killer" flash in... which one? Is there somewhere we can decipher what our flash level includes??
Data, as I've learned, can be a good or bad thing... There is a reason someone was quoted: "ignorance is bliss"
When you are hooked up and running,(meaning synced with the truck, not necessarily motor running) go to the main screen, click on the "OBD2 Adapter Status icon."
Scroll down to the calibration ID. There is where you will find that info.
It will not show the TCM calibration. Just ECM/PCM and FICM.
It might show your vin number in there also. Mine does not.
Best place I have found for help with calibrations is on PHP website and doing a search here in the forums.
And, 'ignorance is bliss' is for those with a great warranty!!!
Have a good weekend!
I finally did get the phone to throw up the menu on each gauge so I could move them around, so thanks for that... It requires me to tap once hard and hold in place on the gauge icon right in the dead center of it. So there's a tip for other Razr owners...
What is the PHP website? Is that the developer's user forums?
Thanks again for your help!
Screen 1:
Engine coolant temp
Engine oil temp
Transmission fluid temp
Battery voltage
FICM main power
HPO system PSI
Screen 2:
Boost
Current gear
Fan RPM
Engine load
IPR load %
VGT %
Is there anything else that's actually important to be monitoring? I'm honestly trying to get it all down to just two screens as I feel that some people may be "over" monitoring certain things. I will be reading EGT and low pressure fuel on gauges mounted to the A-pillar since there's no provision for those.
I'll go look at Power Hungry Performance then...
Cody: I'm watching the other two FICM voltages too, and on the main page. I noticed them drop when I stood on it going up a grade, so they do vary from battery voltage which read 13.8V at the time...
