2 Fast 2 Furious
just hope there is no search for me.
hmm... do you think they could pull me over in a week or so?
I plan on selling that car pretty soon anyways! its in pretty good condition and I think that I can get $800 for it and maybe if I paint it(black) and put new window motors in it I can get $1000
it only has 75000 miles on it and(the digital cluster says it has 105000 because we had to replace the thing with a used one.
and I think that the car is TBI, the engine has a carburetor and I see that it has two injectors facing down.
Hey LK I thought some of those Lambo's were full time 4WD. I dont have time to look it up atm but I guess I could be wrong.
AWD like the talon where its only activated when loss of tracition is what your talking about right? Not full time 4WD?
(Im not picking on anything I just want to make sure I have my facts straight :-)
Chad
Some people feel that the difference is that FT4WD means that you have a low-range, and if you do not then you have an AWD system.
Some feel that FT4WD means that you have a center differential that can be manually locked, and if you cannot 'lock' the front and rear output shafts together then you have AWD.
Some feel that FT4WD is when you have a center differential that splits torque 50/50 between the front and rear, as opposed to AWD where there is either a viscous or electronic system that splits the power front and rear depending on available traction.
Some feel that the difference is that FT4WD is "pro-active", always sending torque to each end regardless of slippage - as opposed to AWD, which is "re-active" and only sends power to the other end when one slips.
Technically, none of these definitions are right or wrong - because there really isn't any true definition of AWD vs. FT4WD. At this point, they're both pretty much just marketing terms - and all they really mean is that power can be directed to both the front and rear wheels. Most automakers call their cars "AWD" because it sounds less 'truckish' and more sophisticated than calling them full-time 4wd. That's true in this case, and all the automakers I listed consider their systems to be AWD rather than full-time 4WD.
The systems:
The Lambo (the Diablo at least) uses a system that sends power primarily to the rear wheels, but can automatically send up to 15% of that power to the front if it needs to. This would make it an AWD system, by most definitions.
The Porsche, IIRC, uses a center viscous clutch that transfers power to the front wheels if the rear wheels slip. Like the Lambo, this would be an AWD system by most definitions.
The Audi quattro system - at least the ones I'm familiar with - sends power to the both the front and rear wheels all the time, and I think uses a torsen center differential. By some definitions this would be a 4wd system, but Audi considers it to be an AWD system. The older Audis had a center differential lock, and were sort of in the middle - some considered them FT4WD, some AWD.
Nothingbutford already described the BMW system, which is good because I don't know much about it.
I do know that BMW considers it to be an AWD system, and that it works automatically with no driver input. The Audi system is closest to the 'original' AWD systems that started appearing in cars - the pioneers were pretty much Subaru and AMC/Jeep. I think Subaru started using in the early '70s (1972?) and AMC introduced theirs in 1973 (but not in cars until 1980). There were earlier AWD systems, but Subaru was the first one to make AWD cars in any quantity.
Okay, now you have more history & details than you probably ever wanted.
LK
Honestly its a nice car. But I just dont have any craving to have another FWD sports car so long as I am still sane.
Chado
Just my 2 cents,
Lance
ie; In the acura 7000rpm shifts were not uncommon. In the truck, I dont like using the gas so I drive like "an old man" (sorry guys
) and I go through about 40-50$/week in gas as opposed to 40$ in the acura.Not sure about the fiero though, only thing I know about them is that a friend of mine bailed out of his when his interior was filling with smoke as it was on fire.
Chado
My solution to the "Ricer Menace" is to do something that has never been done before (at least that I know of)
We should get together, find a good old FORD truck, punch the (expletive) out of it, I mean 1,500hp - I mean 0-60 in 2 seconds - and go eat us some ricers.
At least, this is my Ford truck goal for the next five years.
www.78-79bronco.com/NewRacingBuildup1.html
check out hanks new engine, 626ci big block.
I haven't read the whole thread (YET), but to anyone spouting off about AWD being the 'performance top of the line'. You're kidding. AWD is just something that'll allow cars with little to no torque, get up and go faster. Even the Japanese know you don't put AWD in a performance car. The Honda S2000? RWD. Any car built for performance (Besides that Acura NSX or whatever) is RWD. BMW's, Vipers, Mustangs, Etc.
On topic, most true import enthusiast hate ricers just as much and anybody. They give everyone with a performance japanese car a bad name.
