FE Cylinder Bore
Jun 7, 2012 | 06:42 PM
FE Cylinder Bore
How much out of roundness can a 390 have before having it bored out. I have a 390 thats around 5 thousands out and currently bored to 30 over.
Jun 7, 2012 | 11:49 PM
.005 is quite a bit for a stock street motor with cast pistons, and since you are .005 out of round, you are probably what, .008 or even .010 at some point on the piston?
I knew a guy who worked at a bike shop. They used to put the piston in a vice to make it "fit" in a situation like that. Bet that motor went the distance.
Probe Industries - High Quality Forged Pistons, Shaft Rockers, Main Girdles, Stud Girdles, Engine Kits, Crankshafts and Connecting Rods for Buick, Chevy, Ford, Chrysler, Pontiac, Oldsmobile and Sport Compact Applications. - 866-718-6267
Depends on what you are going to do with it I suppose.
Jun 8, 2012 | 06:59 AM
Its already bored to 30 over.
Jun 8, 2012 | 08:24 AM
Find a 360 block, bore it to 30, and be done with it
.005" out is a bit much. Is it worn .005 bigger than .030 over in one spot like down low in the bore? Or somehow been overbored a bit too far?
Jun 8, 2012 | 08:36 AM
Quote:
Originally Posted by
Krewat
It at the top where its worn. Why a 360 block?
Jun 8, 2012 | 08:59 AM
360 block dime a dozen (sometimes free) and same as 390 blocks
Jun 8, 2012 | 09:06 AM
Yup, 360 blocks are the exact same thing. And very plentiful.
Jun 8, 2012 | 09:44 AM
MIKES 68 F100
360 and 390 are different. 360 stroke is 3.50 and 390 3.78. Plus I was told 390 has better gas mileage since it has longer piston stroke than a 360. Fe complete engines are running $150 each around here.
Jun 8, 2012 | 10:27 AM
davbell22602
The
BLOCK is identical. Not the rotating parts.
Jun 8, 2012 | 02:01 PM
davbell22602
You might be able to go .040 or .050, but the FTE FAQ's say it's a gamble due to core shift:
http://www.clubfte.com/users/ratsmoker/FAQ.html
I'd try to overbore it again fwiw.
Jun 11, 2012 | 07:32 PM
There are plenty of 390s bored .04, .05, .06. Plenty!
puttster
Jun 17, 2012 | 12:51 PM
My 360 block was bored to .060 and i changed to crank, rods and pistons to make it a 390. It runs perfectly and no heat issues.
oldblues2
May 9, 2006 06:55 PM
FORD429PI
Oct 27, 2004 03:02 AM
coreycfv
Sep 19, 2003 08:03 PM
Ds7776
May 7, 2003 10:18 AM
JimmyK1957
13
Sep 20, 2002 06:06 AM
