Oil Pump Leak 85 F-350 w/ 460 auto
Well, I was to drop off my Truck for PA Inspection on Sunday night, but ended up not because of the weather was getting bad. During the inspection the mechanic was going to check out my hesitation issue (appears may be accel pump issue) - In my previous thread a few days ago. Was checking out a few things because I was going to drive it up tomorrow (30 miles). After letting it idle for about 5 mins, I noticed the oil drops on the ground. In checking into it, it appears the oil is dripping around the point where the oil pump goes into the block.
My oil gauge has was ready like it always has, right on the "A" of N O R M A L.
Is that a sign of a bad oil pump / gasket? The truck has 146K miles and is 2x4 auto. We hardly put 200-250 miles/yr on that truck over the last 5+ years (everything is so local that we use the truck for - I know that is not good)
I have not been on here as much as in the past, but after strong consideration we want to keep this truck and get it back to good running condition again.
Thanks
Thanks
I found this post : https://www.ford-trucks.com/forums/1...-fittings.html
Thanks, I was hoping to hear some poss. good news. I can see where to access that bolt through the 'cut out'. I'll check it out
UPDATE: Thanks Beetle! I re-torque to bolt you described and it had some turn left in it. Tightened it up after spending almost 1 hr cleaning up and around the area. Put in oil to bring it back to the dipstick markings and started up the truck and let it idle for a good 15-20 mins. No more leak! If I can get the rubber ring (seal) individually, I am going to replace it though.
Much appreciated, I did notice there was what looked like a gasket under the bolt. Really glad I can get these separately. Wow, that is a really tight space for working down around that area. I am hoping to use a filter relocation kit, but I have the factory oil cooler connections on the factory oil filer angle adapter. There is a spot just behind the oil filter now about 6" back from it. Looks like I could mount the relocation kit there on the cross member where it won't hang below the bottom most part of the frame. It would then be a straight shot down for the oil when I would do oil changes.
sunbelt57
04-29-2015 11:28 PM
600hp48
16
08-16-2009 11:51 PM
LedheadELH
12-03-2004 06:06 PM
GunnerRob
10-25-2003 08:36 AM
