1983 F150 Project
Old Jun 6, 2012 | 08:40 PM
CB_II's Avatar
CB_II
1983 F150 Project
I just picked up a 1983 F150 I plan on completely restoring. Currently an inline 6cyl 300, three speed automatic, 2wd. Eventually planning on a 351 windsor, 4in lift, 5 speed, 4wd. To get it running now though I am looking for an aftermarket carb and having trouble finding anything. Would appreciate any resources anyone might know of for any aspect of the restoration.
Old Jun 7, 2012 | 01:48 AM
rbalsinger's Avatar
rbalsinger
http://www.oemhardware.ca/oempdf/FORD.pdf
Harbor Freight
Eastwood - Auto Body Repair Tools | MIG Welder | TIG Welder | Plasma Cutter | Auto Body Supplies & Accessories
POR15, Inc. - Stop Rust Permanently - Repair Gas & Fuel Tanks
LLOYD'S LITERATURE
P.O. Box 366
Tipp City, Ohio 45371
TOLL-FREE: 800-292-2665 (800 BY-A-BOOK)
FAX: 937-778-4196
E-MAIL: lloydslit@aol.com
WEBSITE: www.lloydsautolit.com
Just a few of the resources that helped me get started.
Oh, by the way, FTE is the biggest help.
Rob
1983 F250 460 ci auto 2 WD
Old Jun 7, 2012 | 09:34 AM
Gary Lewis's Avatar
Gary Lewis
Welcome to FTE, CB_II! I agree that FTE is one of the best, and I would argue "the best", resource for you. However, we can help the most if we know something about you, such as where you live, details about the vehicle, etc. Please go to User Control Panel (User CP) on the upper left side of your screen and fill out the location info. And, some of us put the relevant info about the vehicle in our signatures, which you can also do via the CP. That helps the person trying to help you and keeps us from asking questions over and over.
By the way, while it doesn't really matter I take a minor issue with your use of the term "restore". Typically that means "put back in original state", and that's not really what you are doing. I use the term "restify" for what I'm doing but, as I said, it doesn't really matter as long as we know what you mean.
Anyway, to help us help you we need to know what you are going to do with the truck. For instance, if you are going to tow anything very heavy we'll recommend you stay away from the M5OD transmission as it isn't an HD tranny. For towing or other HD use most would recommend the ZF5. Similarly, we need to know how serious you are about all-out power vs economy. If you are wanting power at any cost then I would recommend a Holley carb, like maybe the 1460 600 CFM unit. I had one on a 351M and with stock jetting the truck got 12.25 MPG and had gobs of power. I replaced it with a stock Edelbrock 1406 600 CFM carb and got a more crisp throttle response and 14.25 MPG. No, it doesn't have quite the top-end power of the Holley, but I rarely, if ever, need it and have gladly traded it for the better economy.
So, tell us more about your truck, your plans for the engine, transmission, and axles plus how you are going to use it and we can do a better job of recommending.
Old Jun 7, 2012 | 12:11 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Howdy CB II,
First off welcome to FTE the most informative Ford truck and more forum there is I have found at least. Also I am a fellow 4x4 converter. We got an 89 F350 2wd crew cab standard we are putting in parts out of an 84 F250 4x4 standard.
We have a F250 351 4x4 89 5 speed and they are great trucks.
How are you going to do the 4x4 conversion my advive for you is find a wrecked or non running that has all the drive train in good shape and use it for parts to convert it over. You start to do it from buying from stores they are expensive. And most of all good luck on finding that carb.
Trav
justaboutbroke
31
Feb 25, 2015 03:07 PM
wbtguy
Feb 21, 2010 10:28 PM
sly22guy
Apr 7, 2007 09:38 PM
Garcia
Aug 25, 2006 12:50 PM
calazo
1978 - 1996 Big Bronco
Apr 19, 2004 11:27 PM
