Motor Mount questions
Old Jun 5, 2012 | 05:14 AM
Norton72's Avatar
Norton72
I have a 1971 F250 4WD that has had a 460 swapped into it. Does anyone here have any idea what kind of motor mount setup should be used for this conversion? I have seen some expensive super-duper off road ten times better than factory ones for sale for about $300 or so, but wondered if there was a more conventional route. I have seen that grinnergetter has a 73 converted to a Highboy with a 460, but I'm thinking his frame is different than mine. If anyone else has one similar to mine I would love to have some pictures and info about the motor mounts.
I have a thread in the 460 forum here with pictures,
it's got a lot of views but know responses. If you look at the pictures you can see what an ugly job was done and it looks quite unsafe to me.
Thanks for your responses.
Last edited by Norton72; Jun 5, 2012 at 05:26 AM. Reason: fingers can't keep up with brain.
Old Jun 5, 2012 | 10:47 AM
crazed87bronco's Avatar
crazed87bronco
I'd have to agree with mark a in his post in the other thread looks like someones fabbed perches up to accept Fe mounts how many bolts are in the rubber mounts is my biggest concern of your setup the rest isn't bad if you feel its unsafe or want a better design there are some places that sell bolt in 460 swap kits
deejaytee
Apr 4, 2010 08:39 PM
buffalobob
Feb 11, 2008 12:01 PM
mathewsc
Feb 11, 2007 10:12 PM
budfinley
Sep 6, 2004 03:29 PM
crazy4Fords
Oct 17, 2002 11:12 PM
