need motor mounts
Old Aug 25, 2004 | 07:51 PM
budfinley's Avatar
budfinley
need motor mounts
I am installing a 460 in my 85 f-250 4x4 and am having trouble finding motor mounts. the lcal parts stores ahve swap kits but at an ungodly price. can any one help me
Old Aug 25, 2004 | 08:36 PM
big hoss 29's Avatar
big hoss 29
About the best place I've seen is the bone-yard. If that doesn't work, look through the newspaper and look to see if someone is parting out an F-250 with a 460, you might luck out. Good luck!
Old Aug 25, 2004 | 08:40 PM
big302's Avatar
big302
you look up that the websites that I list in my post.
Old Aug 25, 2004 | 08:43 PM
fellro86's Avatar
fellro86
Are you swapping one in, or repairing an existing setup? Also, are you referring to the frame mount or the rubber mount?
Old Sep 6, 2004 | 03:29 PM
John Stalnaker's Avatar
John Stalnaker
460 mounts
Stock metal frame brackets for F250 1980-86 are still available from Ford for the 460 motor and rubber motor mounts same also, they will also bolt into F150 chassis. The metal factory brackets for the 85 F250 are E3TZ-6028-C and #E8TZ-6029-B. The two rubber mounts are F7TZ-6038-AA and two special metal brackets for the block are E8TZ-6046-A to hold the rubber mounts.
gtrosema
May 16, 2012 02:25 AM
79-400-POWER
1978 - 1996 Big Bronco
Oct 17, 2007 07:46 PM
tsi9973
Apr 27, 2006 05:43 PM
seth1
1983 - 2012 Ranger & B-Series
Jan 30, 2004 08:48 PM
