Offroad & 4x4
What cools your engine?
Old Jul 13, 2012 | 12:00 PM
  #106
tjc transport's Avatar
tjc transport
i ain't rite
than it sounds like you have an airflow problem, not an engine problem.
Old Jul 13, 2012 | 12:52 PM
  #107
thekingofcows's Avatar
thekingofcows
I think maybe it's an airflow problem out of the engine bay as opposed to in, the fan really pulls good through the radiator.
Old Jul 13, 2012 | 01:02 PM
  #108
alpha/omega's Avatar
alpha/omega
I ran a turkey pan on my Stealth.
And Tom, I have never seen a pusher fan cool an engine better than a puller. IMO they are only good for tight engine bay clearance
Old Jul 13, 2012 | 01:05 PM
  #109
tjc transport
i ain't rite
take the hood off, go for a ride and see if it overheats.
if it does, it is a problem with incoming air. if it don't you need to put a boatload of scallop cuts in the hood.
or just leave the hood off.
Old Jul 13, 2012 | 02:13 PM
  #110
hav24wheel's Avatar
hav24wheel
Kris. Add a pusher with existing fan. Works good with A/C rigs.
Old Jul 13, 2012 | 03:30 PM
  #111
thekingofcows
I may try a pusher fan, I'll have to take my grill out though... there isn't enough room up front. I may build a louver for the hood and see if I can vent out some of the excess heat more efficiently.
Old Jul 13, 2012 | 04:29 PM
  #112
thekingofcows
Well after reading this article, Aluminum vs Copper, I think some of my problem maybe an actual radiator design flaw. The rods of my core are not very close together which would mean I'm not getting as efficient heat transfer as I should. Modern radiator fins are more tightly packed than the old 70s style.
Old Jul 13, 2012 | 09:19 PM
  #113
thekingofcows
Meh.. Another curve ball, the radiator passed my leak test , but tonight I pulled it in the shop to insulate it a little better and I noticed at a cold startup in the shop there was a tinge of steam from the dricerside tailpipe. When I turned the motor off I listened to the dricerside head and could hear a slight boiling sound.. Im beginning to wonder if I have a slight head gasket leak.
Old Jul 14, 2012 | 07:22 AM
  #114
Rogue427's Avatar
Rogue427
If you have a compression tester pull the little valve out and put air to the cylinder with rad cap off. I do this to change valve seals without pulling the head.
Old Jul 14, 2012 | 09:12 AM
  #115
thekingofcows
I don't have one, but I'm sure I could get one. I think I may go ghetto and try a bottle of bars stop leak, I think the leak is slow enough to try it anyway.
Old Jul 14, 2012 | 09:28 AM
  #116
alpha/omega
Sounds like your reputable shop gave you a reputable anus reaming.
Also a prime example of why i will never trust a used engine based off the POs word
Old Jul 14, 2012 | 09:31 AM
  #117
thekingofcows
I don't know, maybe nobody around here can build an engine, they are the most recommended of any shop around me, and i have seen many of their engines over the years. If it can go wrong it will when it comes to my luck with that particular truck.
Old Jul 14, 2012 | 09:43 PM
  #118
kjett's Avatar
kjett
Originally Posted by captain p4
Hold on a second Kris, I have to ask him something else before we confirm.
Did Karl build your motor?
If not, carry on.
Funny I never had a single overheating issue with that motor. Not my fault you want to run used plugs, wires, and anything else your cheap azz can throw on it. Not to mention the fact you can't start or time a motor worth crap. So take that bish!
Old Jul 14, 2012 | 10:44 PM
  #119
fatdan460's Avatar
fatdan460
never knew valeri was a jew name. you learn something new everyday
Old Jul 15, 2012 | 08:09 AM
  #120
captain p4's Avatar
captain p4
I bought all new plugs, your *******es cracked one off in the head and used one you found in Nick's shop, bish!! :flip
