FE 360 help
Old May 22, 2012 | 02:31 PM
vscrl's Avatar
vscrl
FE 360 help
ok so I'm new to working on engines, and I just did an intake gasket installation on my 360. its in a 65 thunderbird (not sure on the year of the motor) anyways the old gasket was almost completely gone in the back of the block, and it was pissing oil everywhere. when i pulled the rocker arm assembly on both driver and passenger side, i forgot to set the motor to TDC, same with reinstallation. i was going through my shop manual just now, and realized i had skipped this step. i already have the rocker arms back in and torqued at 45 foot lbs. Am I going to blow this thing up if I start? is there a way to reverse what I've done? I need help on this from you guys that have done this type of thing before. Again, I'm a total newb, so please be gentle on my stupidity hahaha
Old May 22, 2012 | 04:58 PM
69cj's Avatar
69cj
If you didn't pull the timing chain, you didn't change the cam/crank relationship. Just pull the dizzy and number one spark plug. Bring the engine to tdc on #1 cylinder combustion stroke and put the dizzy back in referenced to #1 cylinder. Then set your timing. Will be easier to turn the engine over if you remove all the plugs but not necesary. Hope you torqued the rockers down one turn at a time front to rear or vice-versa so not to have put any of the push rods in a bind and that the oiling bolt is in the right spot.
Old May 22, 2012 | 05:03 PM
MIKES 68 F100's Avatar
MIKES 68 F100
Do yourself a favor and bump the starter till you are close to tdc , turning over by hand will get old real quick.
Old May 23, 2012 | 07:44 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
No issues with not having it at TDC - just set the distributor, and you're good to go.
If you're worried about anything with the valve train, turn it over by hand, preferably with the spark plugs out, and make sure nothing binds by feel.
Old May 23, 2012 | 05:59 PM
baddad457's Avatar
baddad457
Speak for yourself, bumping the starter and hoping to get it to stop on TDC on the compression stroke gets old even quicker.
Old May 26, 2012 | 05:50 AM
bamaf150's Avatar
bamaf150
Think the key word here was "close"
Old May 26, 2012 | 08:04 AM
baddad457's Avatar
baddad457
"close" is a relative thing. The balancer is only 6" in diameter, and 18" around, so just by popping the hood and looking at it, it's always "close" to TDC. Bumping the starter and hoping it'll land within an inch or two of TDC on the compression stroke is like hoping you'll win the lottery, you've got about the same chances of it happening. You'll spend far more time doing it this way than just grabbing the breaker bar and 15/16" socket and doing it by hand, which is something you're going to have to do after you spend 5-10 minutes bumping the starter, to get it on the correct timing mark. Been there-done that. Now I just use the breaker bar and socket and have it there in a minute.
Old May 26, 2012 | 09:01 AM
MIKES 68 F100
FUNNY i have been doing this for years , screw driver across the solenoid .
i have even hit TDC
Guess i'll go buy a lotto ticket since i am so lucky
Old May 26, 2012 | 01:57 PM
bamaf150's Avatar
bamaf150
"Close" to me would be getting #1 on the compression stroke, thats not too hard to do with the starter.
Old May 26, 2012 | 09:04 PM
baddad457's Avatar
baddad457
i have even hit TDC
I've done it that way too, and long ago I learned to just grab the breaker bar and socket and skip the useless starter bumping, you'll save far more time doing it this way. Doing it with the starter, you'll still need to use the breaker bar after you've spent several minutes playing the the starter. But if that's how you want to use your time, have at it.
Old May 27, 2012 | 11:52 AM
puttster's Avatar
puttster
Turning the brank with a socket and breaker bar, do you need to remove the belts? I have 3. Or remove the plugs?
Old May 27, 2012 | 03:35 PM
1972RedNeck's Avatar
1972RedNeck
i have even hit TDC
I can get it within an inch or two every time. Why is that so hard?
Old May 27, 2012 | 04:08 PM
baddad457's Avatar
baddad457
No, just use the breaker bar.
Old May 28, 2012 | 12:47 AM
bamaf150's Avatar
bamaf150
Good idea to take the neg cable off the battery, if using a breaker bar, just in case.
Jonpoy
Sep 26, 2015 08:43 AM
jesseh39
29
May 5, 2014 03:21 PM
rivet96
May 28, 2011 11:48 PM
turnrjr
Oct 19, 2009 04:20 AM
tonpartain
Aug 15, 2006 08:43 AM
