390 FE starting woes...
Old May 28, 2011 | 07:54 PM
rivet96's Avatar
rivet96
I recently just did a complete top end on my truck (head gaskets, intake etc) now i cant get it to start. It was running beautifully before. Its getting fuel, i can see and smell it, its getting spark, tested the coil, tested the points which turn out to be good. Replaced cap and rotor, mageneto. I also cranked engine over to TDC and placed the dizzy in accordingly. I did a ton of searches on here and cant find anything. I am stumped!!
Old May 28, 2011 | 08:26 PM
akforceten's Avatar
akforceten
I would say ,an this is just a guess but I would say timing is off.
Old May 28, 2011 | 09:25 PM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by rivet96
It was running beautifully before. Its getting fuel, i can see and smell it, its getting spark, tested the coil, tested the points which turn out to be good. Replaced cap and rotor, mageneto. I also cranked engine over to TDC and placed the dizzy in accordingly. am stumped!!
Yeah, fuel and spark but when are you getting that spark? I would suggest you verify you installed the distributor correctly. Pull the plugs, crank the engine by hand and make sure you come up on compression on # 1. I would guess you're180 out.
Old May 28, 2011 | 10:47 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
X2 I bet the timing is 180 out or wasn't set properly in the 1st place with #1 cylinder on TDC of the compression stroke.
BTW #1 cylinder is the front cylinder on the passenger side of the block.
Josh
Old May 28, 2011 | 11:48 PM
Fluxx's Avatar
Fluxx
x3 on the 180 degrees out guess, it's easy to do.
wahlturfcare
Feb 11, 2015 05:24 PM
cope1972
Aug 13, 2014 10:37 PM
4WD_Wolf
Oct 20, 2010 04:54 PM
bulletsneverlie
May 20, 2009 07:22 PM
