Top Dead Center
Old Aug 14, 2006 | 09:49 PM
tonpartain's Avatar
tonpartain
Top Dead Center
What is the most accurate way of determining TDC with the heads attached to the block?
I have a FE 360 with a 390 crank, adjustable rocker arms and push rods, and KB150 pistons. The block came back assembled from the engine rebuilder, minus the oil pan, timing chain cover, and valve covers.
Old Aug 15, 2006 | 02:47 AM
Hypoid's Avatar
Hypoid
Watch the #1 intake valve, as it closes line up the index marks on the timing and crank gears.
Old Aug 15, 2006 | 07:42 AM
pbear6969's Avatar
pbear6969
You can also stick your finger in the number 1 hole while turning the motor over. When it Pushes on your finger you have it. That is just another suggestion that will require two people. Just my 2 cents.
Old Aug 15, 2006 | 08:43 AM
mswift's Avatar
mswift
With your spark plugs out, which I'd assume are, you put your thumb over #1 spark plug hole, and when it pressurizes air against your thumb(either by blowing your thumb off or you feeling the pressure) then YOU KNOW it's on the compression stroke and once to the top, it's at TDC.
My 3 cents.....
jack71
May 23, 2015 12:35 PM
Dashknob
May 20, 2015 07:25 AM
rockfarmer9
Feb 13, 2015 04:42 PM
Gigemags05
Nov 30, 2014 05:21 PM
78 & 87 Super Cab
Feb 24, 2014 10:56 PM
