Finding TDC to Install Distributor
Old Oct 16, 2009 | 03:26 AM
turnrjr's Avatar
turnrjr
Newly rebuild 223 six is still in the engine stand. It is really hard to turn over by hand. Didn't install the rocker arm yet because it would be even harder to turn over. Manifolds are on. I want to put the distributor in. How can I be sure I'm on TDC on the compression stroke? For some reason my timing cover does not have the timing pointer. The cover is the nice cast one, not the stamped one. I'm guessing I need to feel the lifters through the push rod holes on #1? Both should be in the "valves closed" position when I feel the piston top out using a wire through the plug hole?
Thanks
Bob
Old Oct 16, 2009 | 08:45 AM
Old F1's Avatar
Old F1
Yep, sound tight though, put some oil in the cylinders. From a unreliable memory (and you will have to put two rocker arms on) half way through the firing order, (cylinder number three of the firing order), the piston is on the opposite stroke and the intake and exhaust valve are opening and closing so the rocker arms will rock at TDC of # 1.
Old Oct 16, 2009 | 12:41 PM
Julies Cool F1's Avatar
Julies Cool F1
Stupid question, but do you have the spark plugs out of it when you try to turn it over?
Oil or a little automatic transmission fluid in the cylinders works good too - just a squirt.
Here's what I do. Find the #1 cylinder and plug the spark hole with my thumb. Turn the engine over some. When you feel compression blowing your thumb off, get a 1/4 inch dowel about 2 feet long and put it in the spark plug hole until it rests on the piston and hold it straight up. Turn the engine over some more until the dowel stops coming up out of the hole. Close enough.
Old Oct 16, 2009 | 01:39 PM
gdgerland's Avatar
gdgerland
Julie, correct me if I'm wrong, but with no rocker arms installed the valves would be closed at all times. You wouldn't be able to tell which stroke you were on. Without a timing indicator, you couldn't check that.( I guess you could get close if you knew approx where the indicatior would be located) Possibly drop a couple of pushrods on top of the lifters, turn the engine over and watch when both are down? The problem there is that without the valve springs assist, you may have to hold some pressure on the push rods to make sure the lifters are seated against the cam lobe. Seem that the engine shouldn't be that hard to rotate manually with the spark plugs out.
Gil
Old Oct 16, 2009 | 03:17 PM
Old F1's Avatar
Old F1
Um,...... how do you know if its compression or exhaust stroke?
Old Oct 16, 2009 | 04:36 PM
AXracer's Avatar
AXracer
The exhaust valve would be open, or the lifter high in the bore in this case. Do you have the engine side inspection cover off? if so it should be real easy to watch the lifters go up and down, or watch the cam lobes thru the lifter bores if the lifters are not installed.
I too am concerned about the tightness of the engine. Did you assembly lube the bearings, cylinder walls, pistons when installing them, and verify the bearing clearances with plastigauge? With the sparkplugs out, the engine should turn over readily with just a box wrench or 4 way lug wrench on the front bolt.
Old Oct 16, 2009 | 08:06 PM
53OlderThanMe's Avatar
53OlderThanMe
If its still on the stand and the oil pan is off, heres what I did. Turn it upside down and visually watch piston 1 while you crank it with a wrench. Put a mark on the block and balancer when at the top. Then the thumb over the plug hole trick Julie talked about to determine when you are on the up or down stroke. I also marked my distributor cap and housing so I would know when the rotor was on #1 plug and inserted the distributor so everything was at TDC markings. It doesn't have to be perfect, you'll adjust the timing after startup. Don't forget to burn in the cam right away unless you are running rollers.
I'd be a little more concerned with why is it hard to turn over? Something over torqued or bound etc. On the engine stand it should not be difficult to turn the crank with a wrench.
Old Oct 16, 2009 | 11:58 PM
Julies Cool F1
Gil
Nope you guys are both right.....DOY! I didn't connect the dots on the cam/valve thing. Bobby and AX have me all stirred up about disc brakes so I have the "suspension floppy disc " loaded in the brain.
You would have to rotate the engine through a full firing sequence and note on which of the two "Piston toppings" (with the dowel) the cam was in a position where the cam lobes for the two #1 cylinder valves were both flat (or low) - (as opposed to eccentric) at the same time. I think that is the same only different as what AX said above.
Old Oct 17, 2009 | 05:54 AM
turnrjr's Avatar
turnrjr
AX, your right, the side cover off is the easiest way to see the lifters. Didn't think of that. Yes I use Sealed Power assembly lube on the bearings & lifter bores, Crane Cam lube (paste type) on the lifter faces/cam lobes and 30W oil on cyls, pistons etc. I used a very reputable small business machine shop. Owner told me the crank spun very nicely after grinding & align boring. I was meticulous about torques. Crank turned well during assembly. Stiffness developed when pistons were installed. Same shop had bored/honed to matched the pistons. Also balanced. Once I "break" it loose I can turn it over but not easily. After sitting say to the next day, it takes great effort to get it to move again.
Julie, yes I take the plugs out to rotate. I'll try the dowel but not sure if the geometry is right to allow it feel the piston top.
53Older, the pan is on & sealed. I am aware that I need to bring RPMs up immediately on first fire up so as not to ruin the new cam & lifters. Will also prelube by spinning the oil pump first. Thanks guys and gal.
Old Oct 17, 2009 | 08:26 AM
sosotwo's Avatar
sosotwo
if you dont have any of the lifers on all the pistons will be in comp mode some will try to suck some try to compress making it very hard to rotate.
Old Oct 17, 2009 | 12:13 PM
Julies Cool F1
Yes, with the spark plugs in.
Hey Sosotwo...do we know you? Start a new thread and introduce yourself!
Welcome to FTE!
Old Oct 19, 2009 | 04:20 AM
turnrjr's Avatar
turnrjr
Got it. The stick method and watching the lifters worked for finding TDC and determining the compression stroke. Also, I had to build an engine cradle and swap from the engine stand because the flywheel wouldn't fit without hitting the stand supports. Now with the flywheel on I am able to turn over the engine with a ring gear wrench I borrowed from a friend at work. Thanks
Bob
robjs111
1978 - 1996 Big Bronco
Mar 7, 2013 11:02 PM
DPDISXR4Ti
Aug 31, 2012 07:23 PM
angel.aprilia
Jul 15, 2008 02:47 PM
wiznewski
Aug 27, 2003 10:31 AM
sodbuster54
Sep 13, 2002 07:19 AM
