New tutorial: Welding 101, theory and practice.
Elmo
FWIU the easy grind wire is only available in the 11# (8") spools unless you find old stock someplace, but that is unlikely since most ESAB dealers did not stock it. I hope your welder will handle the larger spools, or maybe you can sell your welder for most of the cost of a new welder that will like the Eastwood machines. Most machines that only take the 4" spools also don't take shielding gas.
Elmo
Definitely going to subscribe to this thread. Thanks AX
If you can't come to one of my workshops (??? international airport, RDU is 15 min away, and I do workshops for as few as one student, never more than 4, any 2 or more days of the week.) then buy a copy of Ron Covell's excellent DVD: Basic Techniques for Working with Steel (Ron Covell Creative Metalworking Workshops). When you watch the sections dealing with hammer work, first watch it through to get the idea and info, then turn the sound off and play it again at 1/2 speed and zoom in on his hammer hand if your player has that feature, concentrate on watching how he holds the hammer handle, his arm position and motion, and how and where the hammer face contacts the metal. Finally watch it again at normal speed, this time turn the sound up or use headphones and concentrate on what kind and how much sounds his hammering makes each time the hammer strikes the metal.
There are a few specialized tools that can make metal working easier and better:
First is a bullseye pick hammer.
Helpful hint (warning somewhat self serving...): many on the market I've tried either do not work properly and/or are IMHO very overpriced. I make and sell a better design bullseye pick that is also less expensive. PM me if you want details.
Second is a shrinking disk. This is a heavy stainless steel disk that mounts on an angle grinder that works like magic to help smooth bumpy metal.
Helpful hint: (not self serving this time...) There is a seller on ebay (search: shrinking disk) that sells two sizes, one for a 4.5" grinder and one for a 7" hs grinder at fair prices. The smaller one works nearly as well as the larger one, but do get the corresponding plastic backing disk as well. Don't believe the marketing hype of some more expensive versions, the smooth disk works as well or better than the ones with grooves, lines or ripples in them.
Third is a shrinker/stretcher machine. This is the most expensive investment but is nearly indispensable if making your own patches.
Helpful hint: Unless you have a way too tight tool budget, buy the two body, 2 die set rather than the one body swap-able 2 die set. When working with it you will go back and forth often and swapping the dies will get old in a hurry. Save by making your own stand instead. Harbor Freight sells a cheap light duty clone set, but don't believe the specs, 20 ga is about it's limit. The dies are softer so will need replacing more frequently. The set Eastwood sells is better for up to 18 ga, but the die teeth are courser, marking the metal more/deeper. Mine are Mittler, will do 16 ga and the marks are easily removed with an 80 grit sanding. Never operate without metal in the jaws and store with a piece of oil soaked 1/8" hardboard between the jaws.
Fourth is a set of three (or the medium size if you can only afford one) HMW plastic torpedo mallets and sandbag.
Hint: these are available on ebay for~ 40.00 or less each. You can buy a sandbag and fill it with dried play sand or lead skeet shot, or make your own from sewn up leather salvaged from an old suede or smooth leather coat (be sure it's leather, not vinyl) from a thrift sale or a bag about as good can be made from a section of a not too worn out blue jean leg.
PM me if you want more info on purchasing/making/"tuning" body tools.
