It is doable!
Old May 2, 2012 | 02:15 PM
rideracelivemx7's Avatar
rideracelivemx7
It is doable!
Hey guys, been awhile since I checked in. I've been busy with the new job and the pstroke. Basically I finall got all the goods, arp's comp 910s and 250 hybrids. They should be here tomorrow but I'm pleased to say that doing head studs in these ol trucks with valve springs ARE very doable. You only need to remove JUST the AC box cover, 6screws and it's out. And the bolts on the driver side motor mount. The 2 that hold the blockmount to the frame mount* you jack it up via manifold and that PITA rear stud has
All the room in the world to come out. And with the AC box cover out you can do the very rear passenger side valve spring out with the regular spring tool you get at advance auto or autozone. I highly suggest using the JEGS valve spring micrometer tool to take he guess work out of your valve stem height or installed
Spring height. Which I'm pleased to say my valves were all in spec and only needed a .015 shim to get my goal of 130-134lbs seat pressure
Old May 2, 2012 | 02:53 PM
fordpride's Avatar
fordpride
Good info. Nice to see ya around
Old May 2, 2012 | 02:56 PM
fordpride's Avatar
fordpride
Now go to my irate thread and give some info on the DP
Old May 2, 2012 | 03:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Good to hear you got the springs and studs finished up. I really need to do mine... They've only been in the box for probably 2 years. LOL
Old May 2, 2012 | 09:50 PM
fordpride's Avatar
fordpride
That's called procrastination.
Send em to me I'll give em a good home
Old May 2, 2012 | 11:25 PM
oldbird1965's Avatar
oldbird1965
Hi Steve, what turbo is sitting in there? Probably a S467 if you changed out your head studs, just guessing. But anyway, good to have you back!
Old May 3, 2012 | 12:11 PM
strokin'_tatsch
Since he hasn't made it back to answer, he has an S471 in there.
Mike.. As soon as I get certain a package in the mail from you, I'll think about the head studs. LOL Until then, I don't need the studs or springs.
Old May 3, 2012 | 01:21 PM
rideracelivemx7
Travis, you'll crap if you see how soft the stock springs are. I could compress a decent amount in my hand, with these in the truck and shimmed i feel a whole lot better!!
Yeah glen this is the 471 that's on jake site. I'll be upgrading this to a billet by this summer to help spool times and to clear up the new fuel.
Old May 3, 2012 | 02:21 PM
strokin'_tatsch
Yeah the stock springs are pretty dang soft. I have 2 sets of them sitting on the shelf. LOL. I decided I don't want 910s anymore, so I need to get another set of springs to stick in the heads I'm going to use.
Justin Jantzen
18
Jun 27, 2017 07:58 PM
trozei
13
Jul 14, 2016 07:13 AM
mueckster
37
Aug 22, 2013 09:25 PM
69highboy69
Dec 27, 2012 12:39 AM
shark13
Nov 23, 2010 10:58 PM
