plastic cowl pieces seperate
Old Apr 29, 2012 | 03:24 PM
terry274's Avatar
terry274
Hello, my name is Terry and I bought a 2005 F150 used about two months ago. I have a problem with the piece of plastic that is between the windshield and the hood, this is the part that the wiper arms go through. This part is in two pieces that join in the middle by snapping together. Mine won’t stay snapped together. I can put them together but when I drive the truck they manage to come apart and one of the ends sticks up. I am posting a picture to help explain. Does anyone else have this problem? Am I putting them together wrong?
Thanks, Terry
Old Apr 29, 2012 | 03:35 PM
ryan70asu's Avatar
ryan70asu
Mine does it too. I think there is an article if you search the posts that suggests using a small screw to keep them together. I've never been able to figure out how the screw is actually going to work and plan on buying new ones eventually. They are over $100 each piece from the stealership though.
Old Apr 29, 2012 | 03:52 PM
danorules's Avatar
danorules
I put a screw in mine through the lower tab, just under the hood. I had zip ties holding it but they eventually snapped, I think from the UV rays breaking down the plastic. The screw is doing just fine, and a very cheap repair
Old Apr 29, 2012 | 03:58 PM
evilwayz7's Avatar
evilwayz7
I had the exact same problem after I had my windshield replaced and the way I fixed it was giving it a good solid hit with my hand right over the center where the snaps are. I had originally thought it was snapped together but when I gave it a firm hit it locked into place and now it fits flush together. Was an easy fix for me, good luck.
Old Apr 29, 2012 | 05:15 PM
Stewart_H's Avatar
Stewart_H
Don't forget to check with Tousley Ford Parts, a Supporting Vendor here at FTE. They have incredible prices and can save you a ton compared local dealerships.
Stewart
Old Apr 29, 2012 | 05:31 PM
evilwayz7's Avatar
evilwayz7
Another bit of useful information for you guys is that I have full coverage auto insurance with full windshield replacement. I get up to 3 free windshields a year if the crack or chip is unrepairable. If you get the windshield replaced by your insurance company you can request a new cowl from the auto glass shop and it is considered a safety item and will be replaced along with the windshield. I was told this by the auto glass shop and so I requested the cowl and it was true. Not sure if this is true for all insurance companies but worth a shot.
Old Apr 29, 2012 | 09:03 PM
bigunit54's Avatar
bigunit54
Here you go:
https://www.ford-trucks.com/forums/7...stay-down.html
Old May 4, 2012 | 09:28 AM
bogeyrider63's Avatar
bogeyrider63
Trailering
I did the screw fix last fall, holding it nice and snug.
Old May 4, 2012 | 10:16 AM
jagarcia89's Avatar
jagarcia89
Mine was doing this I went ghetto and laid a bit of JB weld in the seam. It's working great and doesn't look bad at all (the colors match) I looked into is replacement cowls are like 80$ each
SteelHorse08
2004 - 2008 F150
51
May 5, 2017 10:42 AM
BlueOvalFitter
2004 - 2008 F150
20
Dec 10, 2009 03:27 PM
madclone
Bronco II
Apr 13, 2009 07:38 AM
F350-6
Aug 26, 2008 08:03 PM
is300wrx
2004 - 2008 F150
Feb 6, 2006 12:53 AM
