2 stupid questions
Old May 3, 2012 | 04:41 PM
1969furd's Avatar
1969furd
2 stupid questions
I have 2 dumb questions
1. Is there a draain on the block of the 4.2 v6 to drain all the coolant?
2. What fluid ddoe my m5r2 take atf(what version) or gear oil ( what weights)
Old May 4, 2012 | 08:55 AM
Flathead Red's Avatar
Flathead Red
Try this link:
EBSCO Publishing Service Selection Page
Red
Old May 4, 2012 | 10:29 AM
1969furd's Avatar
1969furd
I ttried the link,but you need a login
Old May 4, 2012 | 11:37 AM
Papa Tiger's Avatar
Papa Tiger
You want to use the latest Mercon stuff and yes you can drain the coolant. Also use long life.
Old May 4, 2012 | 11:42 AM
1969furd's Avatar
1969furd
Thanks. Can you tell me were on the block the drain is?
Old May 4, 2012 | 12:15 PM
Papa Tiger's Avatar
Papa Tiger
Because draining the coolant at home opens a whole can of worms for many DIY's. Using the patient drain of the radiator and refil is best. Using a flush Y installed in a heater hose can create a whole lot of problems for you. Adding a corrosion additive is also good.
Old May 4, 2012 | 12:29 PM
1969furd's Avatar
1969furd
I dont mind the worrms i prefer to do all the work myself. For flushing and bypassing ther ad,can i just stick a garden hose in the water pump and flush it like that then refill the system using geen coolant? Or possibly Caterpillar extended coolant?
bnt5
6.4L Power Stroke Diesel
Jun 14, 2018 09:07 PM
golfnut324
Jan 3, 2017 08:54 AM
pstrang
Jun 2, 2008 07:32 AM
irvinf
1983 - 2012 Ranger & B-Series
Feb 12, 2004 02:48 PM
fordmanSLO
4 Cylinder Engines
Aug 4, 2002 02:14 AM
