how do i tell....
Old Apr 24, 2012 | 08:39 PM
miottimouse's Avatar
miottimouse
how do i tell....
good day i have 2 460 engines in my shop on stands 1 internaly 1 externaly ballanced [internal has the round crank shaft spacer external has the weight on the spacer] behind the dampner i had to remove the flex plates to mount them on the stands and didnt think to mark them can any one tell me how to tell the difference in these flex plates? i dont want to get the wrong one as that would be deadly with and unballanced engine thanks for your help
Old Apr 25, 2012 | 03:45 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Sometimes we over look something as simple marking for later ID. Bump to the top....
Old Apr 25, 2012 | 07:01 AM
meborder's Avatar
meborder
just a couple thoughts....
i'd look for counter weights on the flywheel.
very likely that the flywheel for the internally ballanced engine will not have a counter weight.
if they both have counter weights, the weight on the externally ballanced flywheel should be much larger. a machine shop could easily verify the balance before you installed it.
if they are originals, the part number should be on it and Mikeo0oo0o might be able to help you out. If they are not originals, they should still have a part number ... i'd just type that part number in your favorite search engine and see what comes up.
Henrys son
Jun 5, 2011 08:44 PM
tylstruck
Feb 6, 2008 03:16 PM
mudboggin_78
Jan 11, 2008 05:33 PM
broncoman66
Feb 2, 2003 03:31 PM
RGAZ
20
Feb 3, 2001 08:36 AM
