Steering Help
Old Apr 24, 2012 | 12:58 PM
cruizerman64's Avatar
cruizerman64
Steering Help
I have a 74 F100,360, 2wd, 1/2 tn XLT Ranger, and my problem is that my steering is extremely light. Not loose,and it doesn't wander. I barely move the steering wheel and it responds quickly and I have to gently get it back under control. I don't want to replace the whole steering system when it may be something simple, I'd appreciate any input on this,thanx
Old Apr 24, 2012 | 01:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Have your front end alignment checked. You'll need to find a GOOD shop, probably one that deals with heavy trucks because if either caster or camber is out, the axles will have to be bent to adjust.
The only "easy" adjustment on twin I-beams is toe in.
Old Apr 24, 2012 | 10:59 PM
cruizerman64
Thanx alot mike
Old Apr 25, 2012 | 04:02 AM
miottimouse's Avatar
miottimouse
you can also ajust the steering box also to tighten it up a bit unless the front end took a realy good hit in the past i have never seen the need to bend the i beams my self very rare
Old Apr 25, 2012 | 08:19 AM
cruizerman64
I don't know the history of this truck, i'll try to tighten up the box 1st and c how it goes,thanx
ap48379
Jan 2, 2019 04:34 PM
ericdes
1983 - 2012 Ranger & B-Series
May 30, 2011 12:24 AM
moonley
24
Apr 8, 2005 12:35 PM
Mil1ion
1978 - 1996 Big Bronco
Nov 23, 2001 03:13 PM
visegrip
Mar 3, 2001 08:05 PM
