Wrench Light, No Code !?!?!?!?!?
Old Apr 11, 2012 | 10:45 AM
  #31
BLADE35's Avatar
BLADE35
if it were me Id take those numbers again
cuz there was a few problems like 1200 rpm and truck cold just too many discrepancies
I have a feeling some numbers will get better when you take them per my PM
Old Apr 11, 2012 | 06:48 PM
  #32
mtnxtreme800's Avatar
mtnxtreme800
Yesterdays tests started on a cold truck in the AM, ambient temps 55degrees, and pulling a 7000 ld. trailer, except for the WOT runs, trailer was then off. ECT 198/EOT 205 at 70 mph.Those were yesterdays numbers and conditions/ Todays numbers and conditions different were 2500 RPM hi idle, all taken after truck was up to operating temps, and posted todays numbers below right after the / so you can compare.
Baro KO-13.4/13.8 LI-13.5/13.8 HI-13.5/13.8 OR- 13.7/13.8
MAP KO-13.4/13.9 LI-14.3/14.3 HI-14.9/17.1 OR-27.5/18.6 1st pull, 2nd pull 28.7 WOT-3.0/3.0
EBP KO-13.8/13.8 LI-16.8/17.3 HI-18.3/21.2 OR-30/23.3 WOT- 48/48
ICP KO-11/31 LI-889/585 HI-933/1442 OR-2800/1509
ICV KO-.24/.26 LI-1.21/.83 HI-1.16/1.85 OR-3.0/1.64
IPR% KO-14.4/14.41 LI-28.1/21.41 HI-26.4/38.7 OR-57/41.9
FVP KO-11.5/12.0 LI-11/13.5 HI-13.5/13.5 OR-13.5/13.5
FLP KO-11.5/11.5 LI-11./13.55 HI-13.5/13.5 OR-13.5/13.5
FMP KO-48/48.5 LI-48.5/49 HI-48.0/49 OR- 49/49
OK check them out
Old Apr 11, 2012 | 08:12 PM
  #33
BLADE35's Avatar
BLADE35
Things look better today numbers Todays #s were on right side of the / if I understand correctly
So many numbers going almost confusing LOL
You can throw out all the numbers taken while truck cold or when pullen a trailer or while driving theres too many varibles with those and results can widely differ. Thats why I asked for specific conditions ie.. Truck in park with ECT 190* at the diffrent idels Low ,High and KOEO all those conditions are a constant
Now if truck wouldnt start that would be a different story you take what values you can at that point. So there are a few exceptions to the rule depending on conditions but if you can take values the way mentioned above they will be the Most accurite for shure.
But for most part they look good. Is your Battery light on dash coming on at all??
PM sent
Old Apr 11, 2012 | 08:54 PM
  #34
mtnxtreme800
Well glad they are looking good, no battery light either, truck is actually running real good, so my plan is to do the usual longevity stuff mid to late summer, but at least for now I'm OK, I guess the wrench light was a soft code that went away, so far so good, thanks Benny.
Old May 12, 2012 | 09:41 AM
  #35
mtnxtreme800
Had the wrench light come on again twice towing a trailer, pulled over, , restart the truck, no light truck is fine, one of you guys mentioned the delta throwing the light, but I did the hit 15-16 once or twice, very rarely happens, and only for a minute or so, most of the time I'm 5-10 delta, but when it did hit 15 no wrench light. Does anyone know if a max oil temp throws the light, I hit 220 EOT a few times, wondering if that could do it.
homerj
Apr 16, 2019 07:56 PM
4inchlovin
13
Oct 14, 2010 01:04 PM
98SurplusExpy
Apr 9, 2010 04:01 PM
5280
Oct 10, 2009 01:15 PM
Nahkohe00
May 15, 2007 01:03 AM
