2 starter Solenoids?
I wont quote the man since i would butcher the wording but basically temperature under the vehcicle at the pan while moving are hotter than the fluid you are trying to cool down thus no gains to be had in that sense, and aluminum is not compatible with steeel so the bolts are going to corrode unless you isolate from the bolt head.
@tjc transport ok, you have to weigh in on this Tom, although I see you put a like on @AuroraGirl 's post.
I can see how the extra fluid would slowly heat up the same as the rest, most of the heat is coming from the transmission itself.
I am thinking to just give it a service for the time being, make sure I prime the filter as was suggested, and that will probably keep it cool.
That reminds me, my temperature looks good, but there are 2 gauges in the Ford. One is a low/high, the other monitors the temp of the water, best I can tell.
My low/high is always low, but my temp is in the middle. I suspect the sensor to the block could be bad, do these Fords have a sensor in the block?
I see 2 different sensors, one looks like it goes in the block, and the other looks like it's for the radiator, I think it's good to replace both of those. Sensors always go bad, in my experience.
Alan
Alan
Not sure what they are made of
The tail housing is aluminum too
You concerned about corrosion there too?
Gimme a break
You been working on Fords too long apparently
I got my Masters in '98. Where's yours?
Did you click on those links to O'Reilly Auto above?
Here's a pic of my filthy dash. You can see the 2 gauges on the left, which I'm pretty sure if my truck has, most all trucks have, because mine is stripped pretty much, no tilt wheel, no bells and whistles...Maybe I confused you with terminology I used. On my dash I believe it's the top one that tends to go to the low side.
On the O'Reilly Auto side they have what appears to be a single wire temp sensor and a 2 wire to the coolant (I figured the radiator).
This must go in the block with a ring/wire that gets a nut on top of it to secure: https://www.oreillyauto.com/detail/c...tch/mpi0/28331
This says it goes to the coolant: https://www.oreillyauto.com/detail/c...ensor/std0/tx6
The only other sensor they have for my truck is the multi-switch on the column. Mine is fine.
a steel pan with bolts OEM Provided and a sea that almost entirely keeps the steel from touching the aluminum. so only the threads engaged into it are touching, which should have threadlocker anyway.
I cautioned corrosion because 1) aftermarket coatings anad fasteners typically are weaker, 2) there is little gain in having the pan per mark (engineer) 3) the 4r100 pan gives you a drain bolt it is cheaper and it is also extra capacity.
I was born in 98.
they have some pretty smart engineers that usually figure things out well before they ever go into production...like Mark.
and if they do find an issue after production starts, they tend to put out a recall to remedy the issue it as soon as they can.
in 55 years driving i have never had an issue with automatic trans failure because i keep up on fluid and filter service.
and i have only bought 6 new trucks between 1986 and. all other vehicles i have ever bought have been used.
Without a doubt, the first few years the E4OD was a mess. When I rebuilt mine, I looked at all the updates and there are several. Many of them you kind of wonder, what were they thinking? But, they eventually fixed most of their comebacks. I don't believe that Ford [or anyone else] makes a perfect product that does not need improving. I do know some aftermarket companies sell snake oil, but not all of them.
When it comes to steel bolts on aluminum, obvious you have not looked under the hood of most cars. They are everywhere and although on paper, they may have an issue, they're everywhere.
the manufacturer gets the plans and a bean counter says lets delete this, make this smaller, change the routing of this...ect.ect.ect.... we can save $4 per unit.
than when things turn to the excrement from the south side of a northbound facing bull, management blames the engineers instead of the bean counters that made the changes.
That example is bumper brackets. OBS trucks like to seem to have sagging bumpers. They didnt sag new obviously, but Im guessing its more of a mileage +age + incidental or continuous use by the customer that shows its head with age. My truck is older than I am, and the front bumper to my knowledge hasnt been used for a step because my gpa wasnt that mobile and idk what they would be stepping up for anyway. My rear has since its a step bumper. Both sag, front more than rear, but after research its apparently very common to have that. Easy fix but i doubt that was a bean counter more as "does this meet safety regs, and is this a solidly mounted bumper, and does this rear bumper hold a trailer at the stated safe pulling weights" and that just happened to be insufficient over time
If having more ATF in the trans only get all of it the same temp, why would they use a larger pan for the 4WD ?
That part doesn't seem to make sense. Seems the smaller pan is preferable in that regard, if we're just talking about how hot the fluid gets.
Given I have the original pan, I think I will just use it and prime the filter as AuroraGirl stated above. '98, heh? Damn I'm feeling old...but I'm not the only elder in this thread.
