Starter clicks
Old Jan 15, 2019 | 07:54 AM
green_95's Avatar
green_95
Starter clicks
So every now and then when I go to start my 97 7.3 the starter will just click. It's got hot batteries, if you keep cycling g the key and trying to start it the starter will finally engage and start the truck. Is this a starter issue or a solenoid issue? Starter cables and battery cables are good and tight.
Old Jan 15, 2019 | 08:08 AM
knottyrope's Avatar
knottyrope
is it the relay on the fender clicking or that relay and the starter?
If it is the starter and relay, your solenoid is shot
Time for a new starter and maybe an improved one.
Also good to go through this while in there
https://www.ford-trucks.com/forums/1...ou-cranky.html
Old Jan 15, 2019 | 09:35 AM
green_95's Avatar
green_95
I'm pretty sure it's just the starter. Not 100% sure, I'll pay closer attention next time it does it. I did try one to jumping off on the solenoid on the fender well. When all it would do is click I would leave the ignition in the on position and tried to jump it at the solenoid on the fender and the starter would still just click.
Old Jan 15, 2019 | 10:02 AM
knottyrope's Avatar
knottyrope
that does sound like a bad starter if jumping the fender relay only made a click on the starter
Old Jan 15, 2019 | 07:02 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
If you buy a 'noid, stick with Motorcraft only. Lots of debates on starters, but stay away from the OEM unit. Go at least an offset 7.3 SD unit or a Denso.
Also, I would start by cleaning the cables and making sure they are not ****ty.
Old Jan 17, 2019 | 08:30 AM
ernsppw's Avatar
ernsppw
Mine recently did the same thing. Turned out to be the starter. Replaced it with the high torque for an '03. Turns over really fast and starts really quick.
ernsppw
Jan 4, 2019 09:25 AM
anadiller
18
Sep 17, 2017 09:31 PM
Old Ford Lover
Sep 8, 2009 07:09 PM
GWall
Nov 2, 2006 08:28 PM
Sweetred95ta
Sep 20, 2006 04:41 PM
