the gerlims are back
Old Nov 5, 2010 | 08:15 PM
joe f350's Avatar
joe f350
Cool the gerlims are back
YouTube - the germlins have returned
Old Nov 5, 2010 | 08:19 PM
wreckinball's Avatar
wreckinball
if that is the case, the ignition is either bad or something in the wiring of the starter relay.
To make a side note, gerlims whatever they are cant be good but i do know oreo got called out on his master kill switch hahaha
Old Nov 5, 2010 | 08:29 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
its not oero's fault lol.
your starter solenoid is stuck open Joe.replace it and you should be ok again.least that my guess.
Old Nov 5, 2010 | 08:32 PM
joe f350's Avatar
joe f350
in the the one on the starter of on the fender the on on the fender wasnt hooked up at the time of the video
Old Nov 5, 2010 | 10:02 PM
HayMaker5500's Avatar
HayMaker5500
voltage has to pass from battery through the one on fenderwall before the one on starter for symptom, try unplugging the small wire on fenderwall. If it still cranks,that relay is stuck, if it dont then look to junk ignition switch.
Old Nov 5, 2010 | 10:07 PM
joe f350's Avatar
joe f350
at the time both sellionds where unhooked
starmilt's Avatar
starmilt
We all knew your gremlins are back. It will be six years before you can try to get rid of them again. lol
Old Nov 5, 2010 | 10:09 PM
starmilt's Avatar
starmilt
If both selonoids were unhooked and it still cranks, the one on the starter is stuck.
Low voltage can cause it to stick.
Old Nov 5, 2010 | 10:12 PM
joe f350's Avatar
joe f350
ok so can i tap it with a hammer to un stick it
Old Nov 6, 2010 | 12:54 AM
rodneywar's Avatar
rodneywar
no cause knowing you u will break it --- ask your mom to tap it for you
Old Nov 6, 2010 | 03:10 AM
wreckinball
if your starter is old, replace. if it cranks with both of the solenoids unhooked, well then gremlins are definitely back! no whacking the starter with a hammer! hahaha
Old Nov 6, 2010 | 11:06 AM
'87F-2504X4's Avatar
'87F-2504X4
If both solenoids are disconnected then i would look at the solenoid on the starter.
If the solenoid on the fender isn't connected then that would take the ignition switch out of the equation.
Old Nov 6, 2010 | 12:17 PM
mabc926's Avatar
mabc926
Lmao, holy crap.
The first thing I'd do if I where you is get some battery kill switches!
The last thing you want is it trying to take off on you.
Old Nov 6, 2010 | 12:28 PM
WarOzz's Avatar
WarOzz
I would vote low voltage causing solenoid on the starter to stick open.
galute's Avatar
galute
You need a Gremlin Bell. They will keep the gremlins away. it wards off these attacks from the little gremlins, not allowing any more to get onto your bike. If you already have some gremlins riding with you, they will get trapped in the hollow of the bell, and the constant ringing will drive them insane – causing them to lose their grip and fall to the roadway.
