fuel pump?
Old Mar 24, 2012 | 02:48 PM
77 forddddd's Avatar
77 forddddd
fuel pump?
I have a 351 cleveland in my truck and whenever i let it idle or hold the clutch at a light the engine will quit. It idles for about 30 seconds then quits so t dosnt quit right away. I thought maybe fuel filters but i replaced them and it is not better. I only have this problem at idleing when i am going driving it runs perfect. I was wondering if it could be the fuel pump because it is operated by the engine. If anyone has thoughts please let me know. Thanks.
Old Mar 24, 2012 | 04:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sounds more carb related than fuel pump. What's your idle speed? Have you tried adjusting the idle mixture?
Old Mar 24, 2012 | 05:21 PM
77 forddddd
Well it seemed like the fuel supply is getting cut off but it runs like a top wen your driving so i didnt think it was the carb
Old Mar 24, 2012 | 06:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are separate circuits in the carb., one is the "high speed" circuit and the other is the "idle" circuit.
Cruising down the road you're running on the high speed circuit. That one can be working fine, no problems. When your idling, you are running on a different part of the carb. Could be a problem in that circuit.
Check your idle speed and adjust the idle mixture.
Old Mar 24, 2012 | 07:45 PM
77 forddddd
Alright well i dont know how to do much of anything with the carb but i will ask my boss. Thanks
Old Mar 24, 2012 | 07:48 PM
devino246's Avatar
devino246
Read up. The better you know your carb, the easier it is to work on
Motorcraft 2150 2V Theory and operation
Motorcraft 2150 2V internal systems
Old Mar 24, 2012 | 08:09 PM
mark a.'s Avatar
mark a.
When a pump is getting weak you will notice it when you put a load on it, like when your going up a steep grade. If you suspect it, put a psi gauge on it and see what it's putting out.
gfw1985
Aug 20, 2008 11:07 AM
andrewasl
Jul 7, 2006 11:06 PM
Porkfisted
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 27, 2004 09:44 PM
hotbbb
Jan 30, 2004 11:55 AM
donkeychop0009
Jul 16, 2003 11:47 AM
