carb adjustment/fuel pump
Old Jul 15, 2003 | 12:11 PM
donkeychop0009's Avatar
donkeychop0009
1st question, i have a 2bbl motorcraft carb. What exactly does each of the 2 screws at the base of the carb due and what effect does screwing them in and out do.
2nd, after my truck sits for a while i have to pump the exceletator pedal to start it but, why. is my fuel pump allowing fuel to go back to the tank or what?
Old Jul 15, 2003 | 06:16 PM
bubbaf250's Avatar
bubbaf250
1st answer: Those screws are the idle mixture needles. Turning them clockwise leans the idle mixture, counter-clockwise enriches the idle mixture. They have no effect except at idle.
2nd answer: Heat absorbed from the engine causes the fuel in the bowl to expand and leak through the carb's main and idle circuits into the manifold. This creates an over-rich condition on start-up. Opening the throttle plates allows more air to come in, leaning the mixture for ignition.
Old Jul 16, 2003 | 11:47 AM
LxMan1's Avatar
LxMan1
Could also be a bad power valve allowing fuel down into the intake after it is shut off.
Jimmy
66LTD
Sep 23, 2011 03:13 PM
Raptor119
20
Aug 11, 2009 06:24 PM
crazyjed
Aug 30, 2008 08:11 PM
51merc
Sep 24, 2007 11:06 AM
hotbbb
Jan 30, 2004 11:55 AM
