need carb help
Old Jan 29, 2004 | 01:39 PM
hotbbb's Avatar
hotbbb
need carb help
does a carb have to just run on the mixture screws on the bottom of the carb on idle. or does the pump connected to the carb alsohave to be on a little
Old Jan 29, 2004 | 04:13 PM
bubbaf250's Avatar
bubbaf250
If you're referring to the fuel pump, its function is to provide fuel to the carb fuel bowl, on demand, as determined by the float level. When the bowl contains adequate fuel, the float closes the inlet needle valve to prevent flooding (i.e., fuel pump overfilling the bowl).
All of the fuel that the carb uses in any operating mode (idle, main, or enrichment) comes from the bowl, so the bowl must be supplied with fuel to keep from running out. You can disconnect the fuel pump temporarily and allow the engine to run on the fuel in the bowl, but it will not last very long, even at idle. When the fuel in the bowl runs out, the engine will stop running.
At idle, only the carb's idle circuit (regulated by the idle mixture needles) should supply the fuel/air mixture to the engine.
Old Jan 30, 2004 | 11:55 AM
LxMan1's Avatar
LxMan1
The pump is the accelerator pump. It is only used when opening the throttle to compensate for the added air being drawn in until the vacuum signal in the venturies draws fuel thru the booster venturies to keep it running.
monkey jason
Apr 8, 2013 05:23 PM
special blue
1978 - 1996 Big Bronco
Jan 15, 2013 11:17 AM
pierstar
Oct 14, 2003 11:06 PM
blueoval79
Aug 10, 2002 09:36 PM
David
19
Jan 29, 2000 08:01 PM
